**Parting Out** 500hp 1999 Camaro T56 Ford 9"
Old Sep 3, 2006 | 01:21 PM
Tennessee Auto's Avatar
Default **Parting Out** 500hp 1999 Camaro T56 Ford 9"
The car belonged to a friend who I bought it from. He had owned the car over the last three years. The engine, and most mods have less than 10k miles on them. There is nothing wrong with the car I just know its worth more in parts than to sell as a whole. Your more than welcome to come take a look at the car to verify the condition before purchasing. It will be next week before I start parting the car out. I have a couple people interested in looking at the engine while its in the car. I listed a TNT F2 kit below, it has never been on this engine. The engine made 411hp on a mustang dyno before the 90/90 it needs a good tune and smaller injectors. Motor will make in the 430's tuned which is over 530hp at the crank.
Here is a video of the engine running. 1999Z28383FAST
1999 Camaro Z28 Roller $3,500.00 *SOLD*
383 Engine Longblock $4,300.00 *SOLD*
TEA 5.3 1.5 heads with 2.05 intake 1.60 exhaust
Forged Dimond pistons approximate compression 11.2 to 1 with current heads
Forged Eagle Rods 6.125 inch
Forged Eagle Crank 4
Rotating assembly balanced by Evans Automotive
Comp Cams XER 612/244/112 +4
Rollmaster Timing chain
TSP oil pump
90mm Fast TB & 90mm Fast Intake $850.00 *SOLD*
42 lbs injectors green tops $200.00 *SOLD*
Hooker 1 3/4 long tubes with TSP off road y-pipe $425.00 *SOLD*
QTP cutout w/ switch and wiring $75.00 *SOLD*
TSP lid for 85mm $60.00 *SOLD*
Fast Toys Ram Air $50.00 *SOLD*
Asp under drive pulley w/ belt $150.00 *SOLD*
Kateck Belt Tensioner w/ pulley $80.00 *SOLD*
255lph Fuel pump with Hotwire kit $150.00 *SOLD*
1999 LS1 Harness w/ PCM $300.00 *SOLD*
Moser 9" Rear end w/ 3.5" Aluminum Driveshaft $1,900.00 *SOLD*
Moser 9 inch housing
Moser 31 spline alxes
Detroit True Trac posi (worm gear driven no clutchs to wear out)
3.70 gears. has a little wine nothing major.
Complete LS1 Rear Brakes
3.5 inch MMC drive shaft from Dynotech for 9"
SS braided lines front and rear $80.00 *SOLD*
SJM ABS delete and Line Lock with lines $140.00 *SOLD*
Koni double adjustable shocks Road race versions front and rear $600.00 *SOLD*
Ground Control Front Coilover w/ Rear Weight Jackers
600# front springs
150# rear springs
BMR TQ arm $175.00 *SOLD*
6061 Panhard bar with helm joints $75.00 *SOLD*
6061 LCA's with helm joints. $100.00 *SOLD*
K&N FIPK with radiator support $175.00
TNT F2 kit w/ NO2 Daves 90mm plate, heater, gauge, filter, I sold the plate new price $400.00
ZR1 Silver Wheels 17x11 50mm offset and 17x9.5 $400.00
Hoosier 315/35/17 and Kumo V770 275/40/17 Fronts like new rears worn $150.00
3.5 inch LPE Aluminum Driveshaft Stock Lenght $200 *SOLD*
Delphi 85mm Maf Stock $80.00
Delphi 85mm MAF Calibrated w/ bellows and adapter $120.00
Delphi/SLP 85mm MAF $80.00 *SOLD*
35mm front sway bar (largest factory front for the 93-02 was 32mm) $150.00 *SOLD*
21mm rear sway bar
BMR STB 2Point $70.00
13.1 Front Corvette rotors and calipers using Bob Bishop brakets comes with cut spindles. Ready to bolt on $350.00 *SOLD*
Holley power shot filter $15.00 *SOLD*
Wilwood Manual Rack Setup for BMR K-member or modify to use on stock k-member. Less than 200 street miles. $200 *SOLD*
Thanks Scott
Old Sep 3, 2006 | 01:42 PM
tbick's Avatar
what color is the belt tensioner and does it include the pulley?
Old Sep 3, 2006 | 01:43 PM
00WHITETA's Avatar
pm sent!!
Old Sep 3, 2006 | 02:06 PM
99WS-6T/A's Avatar
do you have any pic of the bmr tq arm and which tq arm is it
Old Sep 3, 2006 | 02:42 PM
Jroc99SS's Avatar
Ill take the cut out
Old Sep 3, 2006 | 02:51 PM
DAVIDSANCHEZ's Avatar
HEY MAN MY NAME IS DAVID AND I WAS INTERESTED IN THE REAREND WHERE ARE YOU SO I CAN SEE IF MAYBE I CAN PICK IT UP! PLZ EMAIL ME BACK AT sonora_ta_20022003@yahoo.com ! plz get back to me asap!
Old Sep 3, 2006 | 03:29 PM
MUSTANGBRKR02's Avatar
Default intrested
intrested in belt tensioner and tq arm sent to 27455 shipping qoute fore both ready to buy
Old Sep 3, 2006 | 04:12 PM
dae04383's Avatar
I'd take the asp underdrive pulley with belt/belts email dae04383@yahoo.com
Old Sep 3, 2006 | 04:18 PM
my01ws6's Avatar
Will you take $500 for the nitrous set up?
Old Sep 3, 2006 | 04:26 PM
SDMForever's Avatar
is the cutout electric
Old Sep 3, 2006 | 04:51 PM
SilverBullet73's Avatar
I would like the electric fans with as much of the factory wires to run them as possible! How much?
Old Sep 3, 2006 | 04:59 PM
98REDZ's Avatar
wouldn't be willing to sell the shortblock would yA?
Old Sep 3, 2006 | 07:26 PM
Black FormulaLs1's Avatar
needs an updated list of whats left...
Old Sep 3, 2006 | 07:51 PM
chrismcdaniel's Avatar
pm sent..
Old Sep 3, 2006 | 09:28 PM
qwikz28's Avatar
PM sent
Old Sep 3, 2006 | 10:06 PM
RODS01HUNTER's Avatar
Default Qtp Cutout, Kateck Tensioner,ss Brake Lines
COLOR OF TENSIONER AND DOES IT INCLUIDE PULLEY? SIZE OF CUTOUT?WILL SS LINES FIT 01 WS6 TA? I WOULD LIKE TO BUY THESE ITEMS IF THEY WILL FIT MY 01 WS6 TA!!! PM ME ON WHERE I STAND ON THESE ITEMS!!! THANKS, RODNEY.
Old Sep 4, 2006 | 02:46 AM
98turbls1's Avatar
Pm'd ya
Old Sep 4, 2006 | 03:45 AM
94z28L's Avatar
Originally Posted by 98turbls1
Pm'd ya
ditto
Old Sep 4, 2006 | 04:57 AM
zssman's Avatar
Any pics of the roller. Any 1/4 or 1/8 times on the car.
Old Sep 4, 2006 | 08:46 AM
98REDZ's Avatar
PM sent
