Dash ideas!?
Dash ideas!?
So back to the rats.... I tore my dash all out the other day and found that they were also in the ventilation system. I am planning on also removing the heating and AC now too. The car is a 94 camaro Z28. Should just clean up the factory dash and put it back in, or does anyone think a dash swap would be worth while? Also, has anyone done any custom dashes with carbon fiber or aluminum? The car is getting a cage and stuff soon and will be strictly a street/strip car. I have looked for ideas and havent found much that was totally different. Im not talking about the stick on dash kits either. Post any pictures or ideas! Thanks!
Originally Posted by Z95m6
The TA dash will bolt in.
have you seen any camaros with the t/a dash? i like the idea. i love the way the t/a dash looks. it looks a lot newer than the camaro dash does.
Yeah i too would like to know some facts before i do something like that. I sure as hell would love a T/A dash cuz i could put gauges in the A/C vents. Someone please chime in with info!!!!!
Well my car is an LT1 car but the TA dash is wired the exact same as the 97 Camaro Dash. So i'd assume it would be the same for LS1's so all you have to do is remove your Camaro dash and bolt in the TA dash. You may have to extend a few wires and such but you don't have to rewire anything. The TA door panels will require you to drill holes and you'll have to do some wiring work if you want the power mirrors to work.
