FS: Solid roller CNC heads, Jesel J2K, Dynatech, Accel Gen 7
I have some LS1 race stuff for sale. All of these parts will come available as of this sunday.
I have changed motor plans and I no longer need these items. All of these items have never been ran by me, just left in the box on the shelf.
I will have pictures up tonight of all parts. Just gotta get the boxes out and take some pictures.
If anyone is interested in the heads and rocker arms/and valve covers together, please PM me and we can work out a combo deal
--- BRAND NEW COLA Light weight Pro-Series LS1 crank, 4.0" stroke
SOLD
Crank Pictures
-- Modern Cylinder Heads 6.0 (317 Castings)
- CNC ported, hand finished, epoxy work near pushrod for better flow
- Flow 317cfm (intake) @ .650 lift and carried it out, and
237 cfm (exhaust) at .650 lift and kept climbing higher
- Del West Titanium 2.08 intake valves
- Inconel 1.60 exhaust valves
- Titanium retainers, with special locks for the titanium intake valves
- Welded and reshaped combustion chamber for better flow
- 61-62 cc Combustion chambers
- Valve springs are Comp doubles, but they have 300 lbs + on the seat, and 600 lbs + open
- Will include the spacers to be used with Jesel Shaft rockers
- These are a $3500 set of heads by the way
I have the flow sheet that can be emailed if interested.
SOLD
Pic 2
Pic 3
Pic 4
Pic 5
Pic 6
Pic 7
Pic 8
Pic 9
-- Jesel J2K Mohawk Shaft rocker arms
- 1.7 ratio
- Upgraded fulcrum bearings
- Comes with all bolts and adjusters to be bolted on.
- This is an $1800 rockeram with the options they have
SOLD
Pic 2
Pic 3
Pic 4
--- Used LS1 HEADERS 98-02 GM Dynatech 1 3/4" stepped to 1 7/8"---
- Headers are coated and come with the removable 3" collector
SOLD
Pic 2
Pic 3
Pic 4
Pic 5
--- Accel Gen 7 DFI LS1 System --
- This system was used for startup only, never even left the garage
- Comes with the Accel Wide band option with sensor ( $1200 option)
- All LS1 wiring harness, coil packs harness, injector harness, etc etc
- This system is basically new still in the box
- This is a $2800 + system with the wideband option
SOLD
--- BRAND NEW Nasty Performance sheet metal LS1 valve covers----
- 2" high design
- comes with a -10 fitting on each cover
- Also has a billet fill cap installed
- These covers are polished also.
- Pictures will be coming
- New these would cost $440
SOLD
---- BRAND NEW 5 Gallon JAZ vertical fuel cell with brackets----
SOLD
I accept paypal or cashiers check. If paying with paypal BUYER will pay for the 3% CHARGES
SOLD
Crank Pictures
SOLD
Pic 2
Pic 3
Pic 4
Pic 5
Pic 6
Pic 7
Pic 8
Pic 9
- 1.7 ratio
SOLD
Pic 2
Pic 3
Pic 4
SOLD
Pic 2
Pic 3
Pic 4
Pic 5
SOLD
- 2" high design
SOLD
SOLD
Originally Posted by Car_Guy
Interested in the headers. I'd like to see the pics though.
DO you have an email address you would like the pictures sent to?
Originally Posted by 1stz06
Sent you a pm
Originally Posted by SMKN TA 95
Not a problem, I will have all the pictures up tonight after work.
mhutto01@gmail.com
im interested in that...WHere are you located? I believe that setup will control low impedence injector correct?
Originally Posted by V6 Bird
Send me pics of the Gen 7 setup..
mhutto01@gmail.com
mhutto01@gmail.com
I am in central Illinois. As for controlling injectors, yes it will control low or high impedence injectors.
I will email pictures tonight along with posting them up on here too.
EMail sent with the flow sheet. I scanned it upside down so you will have to rotate it to see it right
All people who asked for pictures should have them in their email INBOX.
Main post will be updated shortly with one picture for each item, and then links to more pictures.
Originally Posted by 1fstTA
send me pics of the gen 7 and the rocker arms please mbrunkerjr9@bellsouth.net
Pictures sent, also links above too.
are the headers sold yet let me know
No they aren't. First come first serve on this stuff. Did you want the shaft rockers?
