random turbo/stock/aftermarket stuff
all a/c parts firewall forward $175
stock k member $50
stock harmonic damper $30
brand new spec ls1 aluminum flywheel $300
stock 98 RAM AIR lid w/ silencer $30
stock 98 cam (made 787rwhp) $50
quiet 10 bolt 2.73 gears $40
quiet 10 bolt 3.42 gears $75
new cometic c5475 mls 5.7L gasket $55
ls1 stock wires $25
ls1 thermostat $15
ls1 cam pos. sensor $20
98 valve covers $50
accel long ls1 wires $35
barely used turbonetics new gen wastegate $525
also have a D&D option'd built t-56 that needs an input shaft and a cluster gear. has upgraded forks and synchros, low miles, viper output shaft conversion (+700) will sell for $1100
any photos just let me know
if i have a crazy price up, tell me
stock k member $50
ls1 stock wires $25
ls1 thermostat $15
98 valve covers $50
Originally Posted by Bird-Of-Prey
new cometic c5475 mls 5.7L gasket $65
Can these be used on a 5.7 block with 6.0 heads? Do they help to lower compression any? Let me know I'm interested.
Originally Posted by smokinHawk
when i used 3.9" bore gaskets on my 6.0 heads, they leaked, switched to the 4.0" bore gasket, they didnt leak.
it's just one head gasket, but it is new and i paid 100 from mti for it
i agree the fire ring may be uncovered slightly with a 6.0 head, better to use stock ls2 gaskets
the cutout and the borla are as a package deal
my paypal is deezuns@comcast.net but add the 3% fee, or pm for address to send a check
yes they do, stock ball joints and bushings
if you want to paypal add 3% to the email above otherwise just check to
David Childress
3240 Lakewood Rd.
Glen Allen, VA 23060
also i just added the air condidtioning system
David Childress
3240 Lakewood Rd.
Thanks David!
