Yella Terra LS1 Shaft-Mount Rocker Arms, 1.7 Ratio
Yella Terra's shaft-mount rockers are an easy and economical way of boosting power, torque and reliability in late model engines. When Yella Terra bolt on rockers are used, the conversion can be performed in the vehicle with no head removal or machining required.
Yella Terra's shaft style rocker arms are suitable for hydraulic roller camshafts and feature oversize shafts and bearings for massive strength, stability and long life. No more needle bearings in your engine! Simply bolt on to original 8mm rocker mountings with no valve cover clearance problems! Eliminates studs, guide plates and special pushrods.
Add to:
Part # Product Price My Cart Wish List
160-YT6624 Yella Terra LS1 Shaft-Mount Rocker Arms, 1.7 Ratio $549.99 Buy Wish
Used 4500 miles $250 shipped firm
Add to:
