1999 WS6 36,000miles W/Mods First $13,000 takes it home
ORIGINAL OWNER This car has the gorgeous Pewter exterior, with the dark Charcoal leather interior. She has all the options- Monsoon stereo, traction control, only option not included is the 12 disc changer. This car is the original owner car and has less than 36,000 miles on it, so the seats are like siting in a new car. The seats are free of tears and any wear. This car will check out on car fax as all original. I'm selling the car for a friend because of relocation. The only minor flaw is that it has a very small scratch on the driver door near the door handle from pulling the car into the garage with the door open and scuffing on the brick. You will not find a cleaner car out there with all these extras. The car was being set up to have a 383 stroker motor build for it, this explains the extras. Time to list the extras.
EXTRAS
12 Bolt Moser rear axle W/3.42 gear, and Auburn Posi
$800.00 Carbon Fiber Drive Shaft
SLP bolt in Sub Frame Connectors
$2800.00 build 4L60E trans W/Vigilante 3800 Stall Converter
SLP Ceramic Coated full length Headers
3 inch SLP Off-Road Y-PIPE
Dynomax UltraFlo Muffler W/2 4 inch round stainless steel tips
SLP Air Box W/K&N Air Filter
MSD Spark Plug Wires
NGK TR6 Spark plugs
Crane Cam 1.8 Roller Rockers W/Stronger Springs
3 Tier Gauge Pod
1 Auto Meter Pro Comp AIR FUEL Gauge
1 Auto Meter Pro Comp NITROUS Gauge
1 Auto Meter Pro Comp TRANSMISSION TEMP Gauge
2 BFgoodrich G-Force T/A 275/40/17 (front)
2 Nitto NT555R 315/35/17 (rear)
All four tires were installed @ 33,500 miles still like new.
After reading all those extras you can see that this car only needs the stroker motor and the bottle to be a 600hp beast. If you are looking for a clean high performance Trans Am look no further. If you have any questions E-mail @ annaw1981@yahoo.com or call Matt @ 586-216-9401. If I don't answer, please leave a message and I will call you back.
EXTRAS
NGK TR6 Spark plugs
3 Tier Gauge Pod
