Broken Driveshaft pics
Old 10-26-2006, 09:41 AM
SuperSport4life's Avatar
Default Broken Driveshaft pics
2 runs after my 12.47 run my driveshaft took a dump. I was launching at 4.5-5k rpms. Luckily a buddy of mine had a stock one lying around. I am planning on upgrading to a chromoly driveshaft and a drive shaft loop when I do a 12 bolt. check out the pics:
IMG]http://i50.photobucket.com/albums/f308/NyRicanB0i/brokendriveshaft-3.jpg[/IMG]
Old 10-26-2006, 12:14 PM
cwaldt's Avatar
Good thing it didn't cause any major damage. Makes me reall want to consider what kind of driveshaft I get before I start driving my car.
Old 10-26-2006, 07:00 PM
SS4Matt's Avatar
that's pretty common, my buddy and i twisted a stocker aluminum one on some stroker 383 LT1 car that he was tuning....so my stocker went in the custo's car and away it went
Old 10-26-2006, 07:58 PM
INMY01TA's Avatar
Same thing happened to mine.
Old 10-27-2006, 05:33 AM
EPP
EPP's Avatar
https://ls1tech.com/forums/gears-axles/576641-3-5-aluminum-driveshaft-1200-hp-rating.html
PST 1200 hp rating. Bob
Old 10-28-2006, 12:36 PM
2002_Z28_Six_Speed's Avatar
I would like to analyse that fracture.
How far would something LIKE this get you? Would it hold?? It is expensive, though...
http://www.lingenfelter.com/store/ln0351.html
Old 10-28-2006, 01:05 PM
wolfy's Avatar
how much power are you putting down? i broke mine last night, and im COMPLETELY STOCK. dead hooked ON STREET TIRES at a 3k launch...im just boggled that my rear didnt go first.
Old 10-28-2006, 01:56 PM
What kind of tires are you using to hold that much RPM at launch?
Old 10-29-2006, 12:02 PM
275/40r17 mickey thompson et street drag radials
Old 10-29-2006, 12:28 PM
chrisco's Avatar
Those aren't really "street" tires... they're street legal drag radials. But I too am suprised your diff didn't blow first.
Old 10-29-2006, 01:53 PM
That is what I thought. I can only launch that high on DR, also. My gearset or driveshaft hasn't blow either but I don't do it very much.
I can't believe you got 17'' MT hehe Didn't know they made them that high. I wish I could get MT on 15'' but with Z28 brakes it doesn't seem to fit.
Old 10-30-2006, 08:34 AM
JeepinBash's Avatar
that's some quality carnage right there. i like it.
Old 10-30-2006, 08:57 AM
we_todd_did's Avatar
When mine broke it bent my brand new torque arm, I called eddlebrock and told them it had bent on its on and they gave me a new one.
Old 10-30-2006, 10:16 AM
Krab's Avatar
Welcome to the broken driveshaft club! Yours looks just like mine when I broke it at the local drag strip, same location mine failed.
I wouldn't count your chickens before they've hatched. You might have caused damage to your rear without it showing any real signs yet (excessive shavings/chunks of ring/pinion gear in the fluid). Only real way to know is to take the cover off and inspect the internals. I thought the same thing as you when I took out my driveshaft. I later found out that I took out both the driveshaft and carrier at the same time.
Old 10-30-2006, 01:57 PM
DeviLs1's Avatar
Yeaaappp been there, i also have mickey thompson et drag radials... I learned to "Slip" the clutch...
Old 10-30-2006, 06:47 PM
The track was hooking man.......... I was bogging until I was launching at 4500 rpm's
Old 10-30-2006, 06:48 PM
Man-Crush Warning
01sscam's Avatar
looks familiar, mine did that when i was completely stock.
Old 11-07-2006, 09:44 PM
cowboysfan's Avatar
looks like ur tq arm is till attached to trans end and u r launching at waht rpm! man I'm surprised thats all u broken. be carfull.
cowboysfan
Old 11-07-2006, 10:21 PM
koolaid_kid's Avatar
Bummer. I like my Strange Chromemoly driveshaft, not too pricey and upgradeable if I change my rear end. Using a BMR driveshaft loop.
Quick Reply: Broken Driveshaft pics
