Lots Of Parts For Sale
I have parts off a 98 camaro z28, a 97 trans am, a 96 camaro z28, a 95 formula, and 2 94 camaro z28's
here's a list of everything i can think of that i have left
if you need anything that is not on the list please send me a pm i may have it
94 camaro z28
complete LT1 pullout with 52k miles runs perfect with all accessories, PCM, and wires $1300 OBO
red beager panel-$25
gray t-top headliner in perfect condition-$60
gray sunvisors look great but the elastic straps are streatched-$25 pair
tail light wireing harness-$15
headlight assembly-$80
A4 shifter assembly with all lines-$60
front seatbelts in gray-$40
starter-$60
starter ring-$20
stock stall-$20
A4 radiator-$80
steering fluid resivor $20
coolent resivor $25
washer fluid resivor $10
A/C condinser-$40
dash-$125
e-brake handel assembly-$25
center console with A4 plate-$50
HVAC control panel-$25
headlight control panel with fog light button-$20
steering column with airbag and wheel-$150 or $50 for the bag and $100 for the column and wheel
passenger air bag-$40
window/mirror controls-$40 for the pair
hood struts with brackets-$25
hatch struts-$20
red camaro z28 hatch with spoiler-$50
rear view mirror-$20
defrost button-$5
A4 pedals-$40
key fob-$10
t-top weather strip (does not leak)-$40
t-top divider on the roof-$15
t-top mounting brackets-$10 set
t-top holders that mount in the trunk-$30
a pillars-$40
b-pillars-$10
gray dome light-$10
drivers door in red with new window motor-$100
yellow front turn signal lenses-$20 pair
tail light wireing harness-$20
red beager panel-$30
hatch weather strip-$10
spare tire-$20
a-4 steel driveshaft-$40
stock torque arm-$20
323 complete stock rearend-$250
k-member-$50
motor mounts-$40
complete spindel assemblies-$100 pair
rear brake calipers-$80 pair
4 stock rims with bald tires-$80
steering rack-$40
charcoal interior panels- make offer
gauge bezel-$20
red camaro z28 hood-$40
95 formula
stock maf sensor (descreened)-$40
stock cat (it should be good but i don't know for sure it came with the car)-$20
drivers door (needs window motor)-$75
3-channel abs module-$40
t-top a-pillars-$50
t-top mounting brackets-$15 set
passenger front fender in silver-$60
rear bumper in silver-$40
complete set of gray cloth seats-$100
stock rockers-$20 set
stock pushrods-$10 set
brand new water pump-$100
gray cloth door panels-$50 pair
k-member-$50
steering rack-$40
front bumper support (the foam thing with the bracket)-$30
a/c compressor-$50
brake booster-$20
smog pump-$25
hatch in silver-$50
gas tank-$20
e-brake handel-$25
t-top holders in the trunk-$30 pair
headlight support bar-$80
complete horn assembly-$25
yellow front turn singnal lenses-$25 pair
stock throttle body with all sensors-$40
stock LT1 intake manfold-$60
stock LT1 fuel rails with regulator-$50 set
MAP sensor-$20
hatch weather strip (does not leak)-$10
radiator support-$20
fuel lines-make offer
center console with M6 shift plate with a broken boot ring-$60
headlight controls-$20
hatch release assembly-$10
gray dome light-$10
brake master cylinder with resivor-$20
washer fluid resivor-$10
front strut assemblys with new shocks-$80 pair
side mirrors in silver $30 each
k-member bolt set-$10
stock PHB-$20
gas tank straps-$20- pair
96 camaro z28
defrost button-$5
white z28 spoiler with 3rd brake light-$30
gauge bezel-$20
hood hinges-$20 pair
10 bolt housing-$80
k-member-$50
rear dif cover-$20
stock pinion-$20
97 trans am
fog light switch-$15
passenger interior mirror trim-$5
steering column with airbag and wheel with volumn controls-$160 or $50 for the bag and $110 for the column and wheel and volumn controls
factory amp-$40
owners manual-$7
starter with only 76k miles-$60
brake booster-$20
PCM holder-$5
motor mounts-$40 set
drivers t-top with key $160
stock stall-$20
complete 323 rearend-$250
98 camaro z28
stock fuel rails with pressure regulator-$50
HVAC controls-$25
tan hard top headliner-$30
3 channel abs module-$40
red camaro z28 hatch with spolier-$50
drivers door in red-$100
e-brake cables (complete set of all 3)-$45
gas tank straps-$20
pairstock LCA's $20
hatch struts-$20 pair
rear tan seat belts-$30
factory amp-$40
tan interior plastics-make offer
shock sensor-$10
tan dome light-$10
drivers mirror and window control panel-$25
rear axils-$25 each or $40 for the pair
tail light harness-$20
15 stock lifters and rods with only 42k miles-make offer
door handes bezels-$15 pair
door panels in tan leather-$50 pair
brake booster-$20
other parts
Vats bypass module-$15
hatch pop buttons-$5 each
camaro z28 3rd brake light-$10
cig lighters in gray and black-$7 each
stock torque arms-$20 each
pirelli scorpion zero 285/50 R 18 with only 1k miles look new-$300 for all 4 tires (they are sport truck tires)
all prices are OBO and plus shipping
i'm located in mansfield tx 76063
check my feedback if you need to verify i'm an honest person
my paypal is misdswimmer@hotmail.com
thanks
robbie
94 camaro z28
starter-$60
starter ring-$20
stock stall-$20
A4 radiator-$80
coolent resivor $25
A/C condinser-$40
dash-$125
hatch struts-$20
defrost button-$5
A4 pedals-$40
key fob-$10
a pillars-$40
b-pillars-$10
gray dome light-$10
spare tire-$20
k-member-$50
motor mounts-$40
steering rack-$40
gauge bezel-$20
95 formula
t-top a-pillars-$50
k-member-$50
steering rack-$40
a/c compressor-$50
brake booster-$20
smog pump-$25
hatch in silver-$50
gas tank-$20
e-brake handel-$25
MAP sensor-$20
gray dome light-$10
stock PHB-$20
96 camaro z28
defrost button-$5
gauge bezel-$20
10 bolt housing-$80
k-member-$50
rear dif cover-$20
stock pinion-$20
97 trans am
factory amp-$40
owners manual-$7
brake booster-$20
PCM holder-$5
stock stall-$20
98 camaro z28
HVAC controls-$25
gas tank straps-$20
pairstock LCA's $20
factory amp-$40
shock sensor-$10
tan dome light-$10
brake booster-$20
other parts
thanks
robbie
Robbie,
The 97 Trans Am steering wheel, are you willing to sell it seperate from the colum, if so I have a few questions, is it assembled, is it leather and if so any pics? My factory 93 wheel is kinda gone to ****.
hey how good of shape are the front fender and the rear bumber for the formula and how much are you willing to ship them for?? o and wondering if you are sellin a hood for that formula too
wtf, I thought I had posted in this thread already
well I am interested in the grey cloth door panels, and have a few other parts I want if you have them
can I see some pictures of the panels
