Power Steering Rack!! Help!
Old 11-06-2006, 03:32 PM
DangerousCurvesZ28's Avatar
Default Power Steering Rack!! Help!
I found out today after putting my car on the lift that my PS rack is bad...does anybody have any reccomendations on a new one? Thanks
Old 11-06-2006, 08:01 PM
mitchntx's Avatar
A new one? I think GM will probably be your best bet for that.
Old 11-06-2006, 08:46 PM
Ok NVM i ordered one today...
Old 11-07-2006, 12:10 PM
01badz28's Avatar
I maybe a little too late, but if you don't order it from GM be careful. The LT1 racks and LS1 racks are slightly different, and the parts stores don't seem to know that. And no, the two racks are not interchangeable (don't ask me how I know!).
Old 11-07-2006, 12:41 PM
trackbird's Avatar
Apple Valley Chevrolet?
Old 11-08-2006, 01:05 AM
LS1TechRulez's Avatar
lol....been there done that too
Old 11-08-2006, 10:39 AM
lo_jack's Avatar
To clarify, you can put an LS1 rack on an LT1 car, but you should not
go in reverse.
I put an LS1 rack on a V6 car, which uses an LT1 rag joint equiped rack.
The differences are the connection to the steering shaft and the ratio of the rack.
The LS1 rack is closer ratio, and uses a double ujoint style solid connector as opposed to a failure prone loosey goosey rag joint.
They are butter to swap out, and if you had not just laid out for a new one I would say you can get an LS1 rack from TA creations or any yard for that matter, just check the boots for leakage and the tie rods for trueness.
Don't forget to get an alignment.
Quick Reply: Power Steering Rack!! Help!
