Drag Racing Tech
Bigger sway bar ?
Old 11-11-2006, 11:24 AM
Brianss1's Avatar
Default Bigger sway bar ?
Would a aftermarket sway bar help me at the track over the stock one I have now.No track time yet,been busy with work and personal stuff but want to go this spring and see how my car does.I was thinking about this one here from Spohn would work with my set up.
1" (25mm) Solid 4140 Rear Sway Bar
Item: 923-Rear
$147.50
This rear sway bar is constructed of 1" (25mm) solid 4140 chrome moly. Our bar stock is 4140 chrome moly heat treated spring grade steel. The bar is entirely heat formed and coined as one piece. We put our bar through this extensive process to insure that the final product will be the strongest, most durable bar on the market, and that it will be the most resistant to form alteration. Most aftermarket anti-sway bars are cold-bent, making them weaker at the bends, and more vulnerable to shape alteration.
Rear sway bar includes polyurethane bushings and end links, everything you need for installation and maximum performance! Sway bar is available powder coated bright red or gloss black.
Drag Racers: This rear sway bar is perfect for those looking for a stock style heavy-duty rear sway bar to keep things level on those hard launches, it's up to the task!
Old 11-11-2006, 06:17 PM
Firehawk441's Avatar
Many people have used this bar with success. It's also one of the easiest to install.
Old 11-11-2006, 07:13 PM
Brianss1's Avatar
looks like it has been tested out and works good for what it is and easy install to boot that i like.thanks for the reply.now all i have to do is get some drag radials for my stock ws6 rims or decide on if i want to buy a set of skinnys / drag tire set up.
Coal Mining Director
onfire's Avatar
Just took one off tonight that went 1.42 sixty ft.
I'm moving on up to the Spohn Drag bar for my transbrake.
Looks new...less than 100 miles on the bar. Black powdercoated. Yours for $100 plus shipping if you want it. It's much beefier than the stock bar. Just PM me.
Old 11-12-2006, 02:10 AM
94z28L's Avatar
i like my spohn drag bar, nothin like a 1 5/8" diameter rear sway
Quick Reply: Bigger sway bar ?
