Lots of stuff for sale!
Many Parts for sale--consolodated now which is what I should have done from the get go. Sorry Mod.
706 Casting heads (4.8/5.3) Unknown milage, but fairly clean and assembled. $225
I have a set of DRE 1.7 rockers for sale due to the fact we changed setups and will require offset rockers. These are the same rocker they use to private label for Comp. They have adjustable pushrod cups (ARP) but do require a very short pushrod and need the pushrod holes opened up in the head (top and sometimes bottom). These rockers also need a very good spring for stability even though they are one of the lighter aftermarket rockers on the market. This set has about 2000 street miles with some high-RPM use but look new other than shiny pushrod cups. Asking $500 for these.
CamMotion 246/250 .634/.627 113+3
Great 408 cam! Good drivability and can make 520+ RWHP with great torque.
Cam has about 5k miles and is in the box w/ its cam card.
Asking $250.
CamMotion 239/243 .612"/.618" on a 112+2
This is an aggressive cam for stock cubes (most likely needs flycutting or reliefs depending on head used). This cam has about 2k miles on it, we pulled it out when we went to a bigger motor. Have box and card. $200
Spohn SFC's Tubular style mild steel, new in the box. Black powdercoat. Just an extra set no one picked up. $120
TCI Elastomer 25% Underdrive Balancer for 1997-2004 Corvette, New never installed. $285
Thanks,
John
214-674-0141
Asking $250.
Thanks,
John
214-674-0141
