Slow passenger window? Check this out.
Old Nov 16, 2006 | 07:38 PM
gnomee's Avatar
Default Slow passenger window? Check this out.
Hello Everyone,
I just started advertising here on ls1tech and wanted to get out here and let everyone see our product.
We are a new company trying to bring new technology to older cars. GM fixed the problem with underpowered windows in there big SUV's but they didn't care much about our f-body's.
We created a cheap kit with VERY detailed instructions that will allow ANYONE with a toolbox to install this kit and improve window motor life and function.
On our site you will see before and after videos. These videos are shot with the cars off and we did not grease or clean the tracks, so greasing the tracks will only improve the benefit of the kit.
The kit is $29.99
This is only a remedy for the passenger window.
By default power comes from your battery, thru your Body control Module on the passenger side then over to the driver side switch. Then back to the passenger window to operate it. This long path of power reduces the amperage and voltage the motor gets by quite a bit.
So your motor is underpowered which
1. reduces motor life
2. reduces motor strength
3. makes the breaker blow and the window stop.
This kit will get power to the window directly from the battery. It will improve power to the driver side when both windows are being rolled up and down at the same time due to the switch on the driver side no longer needing to power the passenger side.
From the factory The driver side is powered fine when it is the only one operating but everytime you roll them up or down together they are both getting hit with low volatage. The kit will wake up your passenger motor, but you driver side may be going out if it is acting like the passenger window.
All the cars in the videos on the site have no driver side issues. Getting this kit before you have problems will only help make sure you don't have these issues early.
Window motors WILL fail like any electric motor, but they should not fail so soon. Our window motors should be able to last over 10 years during normal use when they are properly powered.
Old Nov 16, 2006 | 08:50 PM
2000Firehawk's Avatar
Cool...
Looks good, I just ordered..
Thanks for engineering this product.
I hate my pass side power window
Dave
Old Nov 16, 2006 | 09:00 PM
gnomee's Avatar
Thanks for you order.
Once you install it please post back here and let us know your thoughts.
Old Nov 18, 2006 | 04:48 AM
Jimmy P's Avatar
TTT Let us know how it works out. I am interested in this myself.
Old Nov 18, 2006 | 09:25 AM
Ok, will do...
Old Nov 18, 2006 | 10:05 AM
Phoenix 5.7's Avatar
if our window has slowed to a hondas pace, will this help, or is the motor too far gone?
Old Nov 18, 2006 | 10:57 AM
gnomee's Avatar
That is exactly what the kit is going to help out. Check out the videos on our website. You can see before and after speed differences. Quite amazing what correct power can do.
Old Dec 7, 2006 | 03:25 PM
autotrix's Avatar
Closed ex-Sponsor Account
TTT.. more info @ https://ls1tech.com/forums/lsx-parts-sale/609435-slow-passenger-window-check-out.html
Old Dec 13, 2006 | 06:30 PM
autotrix's Avatar
Any other feedback or installs out there lately???
Old Dec 30, 2006 | 01:01 AM
2002/ws6's Avatar
what if my passenger window goes down real slow then stops then five min. later moves another inch down then stops will this "fix" help out my window its pretty f' up
Old Dec 30, 2006 | 07:03 AM
Viper's Avatar
To the above poster:
No, you're motor is going. Repalce it with new AND the kit from this guy.
Old Dec 30, 2006 | 02:16 PM
gnomee's Avatar
The kit might make the motor work better, but at this point it sounds like your motor is pretty far gone. The kit will help keep this from happening so soon.
If you notice on our videos the forumla window would not go back up all the way. If I tried to roll it down then right back up it would stop like that wait 5 min and it would roll back up. Then If I tried to roll it down again right away it would stop and do like you describe.
If you really don't want to replace the motor the kit will not hurt anything and if it still does not fix it you are a step ahead of it happening again when you do replace it.
Old Jan 30, 2007 | 02:48 AM
lsp408's Avatar
just order it for my 02 ss, hope will work good XD
Old Jan 30, 2007 | 06:44 PM
autotrix's Avatar
Oh....it will!
Thanks for the order, please spread the word and keep in touch for new products soming soon!
Old Jan 31, 2007 | 02:39 AM
OliGeorgs's Avatar
Interesting, I have only had problems w/my driver side window. Propably because I never use the passanger window, but the driver side window is realy slow. But you have no fix for that?
Old Feb 6, 2007 | 10:07 PM
autotrix's Avatar
No.
The factory wiring for the drivers side is sufficient and most problems are simple like; lack of lubrication.
Old Feb 11, 2007 | 05:20 PM
The Dragon's Avatar
Will this interfere if one has express down for driver and passenger-side? If not, I'll order 2
Old Feb 11, 2007 | 07:05 PM
Quick96ss's Avatar
will this work for the driver side window too????
Old Feb 11, 2007 | 11:30 PM
gnomee's Avatar
As long as the kit is wired after the switch and before the express down module it will work just fine and will still improve window performance.
This is only for the passenger side window.
Old Feb 12, 2007 | 12:02 AM
The Dragon's Avatar
Ordered 2 kits and sent you a shipping address correction via PM
