FS: Camaro Black Halos
Old Nov 22, 2006 | 06:33 PM
98redM6's Avatar
Default FS: Camaro Black Halos
I've got a pair of black halos for sale.
One light is in good condition with everything working.
The other light had the housing broken, so I replaced it with an oem housing that I had attempted to do the whistler mod on, the halo trim plate covers up the whistler mod anyways. The housing, lens, and halo trim plate are separated. The only thing that will have to be fixed is the LEDs replaced on this one, a hole drilled in the new housing for the wires to go through, and the rubber trim re-glued to the lens as it is coming off on 50% of it.
These are in good shape with other than the LEDs not working on the one headlight. Included is the mounting brackets and clips as well. These would be perfect for someone that was planning on buying a pair and doing the Halo LED color change mod.
Here are some pictures:
I'm asking $85 shipped through UPS or Fedex. Paypal is preferred, but can take US Postal Money Order as well.
Old Nov 23, 2006 | 03:35 PM
98redM6's Avatar
The top picture is of the disassembled headlight with the bad halo LEDs and the bottom one is of the assembled headlight in good condition.
Again the top one has rubber that needs to be glued down, a small hole drilled for the halo wires to go through the housing, and new LEDs. This project takes probably $10 max for the LEDs, the resistor, and the glue for the rubber. I'll throw in a tube of the clear sealant for the headlight to be put back together.
Happy Thanksgiving everyone.
Old Nov 24, 2006 | 03:46 PM
98redM6's Avatar
SOLD to CULATR. Thanks.
