FS: Complete LT1 Big Solid Roller Setup
Selling a complete set up for a nasty solid roller.
This came out of another board member's 396 LT1 motor that I recently bought. Since I am too much of a ***** to run a huge solid roller, my loss is your gain.
You get:
Cam Motion Solid Roller .670/.670 lift 260/266 at .050 110 LSA .9" base circle (see longer pushrods below)
Complete set of COMP Cams Solid Roller Lifters
Comp Cams 7994 Pushrods. 7.950" to make the correct geometry with the smaller base circle cam.
This entire set up was purchased brand new by the other board member and was run for about 2000 miles. Yes, two thousand only, you read that correctly. I am going to run a hydraulic cam because I like to tool around on the street too much for a big solid.
I need to get $500 plus shipping. Look up the parts and that's about half price. Pretty damn good deal for nearly new stuff. I want to sell it all as a set.
I tried to take detailed pictures, but the smaller features like part #'s don't turn out very well, plus I had to reduce the pictures a lot to fit the forum limits.
This came out of another board member's 396 LT1 motor that I recently bought. Since I am too much of a ***** to run a huge solid roller, my loss is your gain.You get:
I have to check. Have another member who said he sent a deposit (via snail mail). However, I am on vacation away from home. Will be back in a couple days and confirm if his deposit arrived.
I will let you know if he did not in fact send the deposit.
