Boosted Stock Bottom End guys IN HERE!
Old 12-02-2006, 07:19 PM
LS1Tech Sponsor
Superman09's Avatar
Default Boosted Stock Bottom End guys IN HERE!
Only if your running a stock bottom end and some boost.....
1.) What system your running.
2.) How much boost.
3.) How much rwhp.
4.) Transmission.
5.) Meth, yes or no.
6.) How long you've been running this... approx miles.
7.) Any symtoms of engine failure so far?
Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 12-02-2006, 07:25 PM
caindo's Avatar
D1 procharger
9.5psi
~600+
stock 6spd
no
20k miles
none
05 gto (ls2)
Old 12-02-2006, 07:34 PM
GTOLarry's Avatar
2.) How much boost.
3.) How much rwhp.
4.) Transmission.
Thanks!
2004 GTO LS1 Vortech Kit
9.5psi
600rwhp
6sp
Alkycontrol - yes - 100% methanol
12K mi
running clean and strong
Old 12-02-2006, 07:41 PM
Jamesbond2509's Avatar
2.) How much boost.
3.) How much rwhp.
4.) Transmission.
Thanks!
6L iron block
12lbs
HP - TBD
Snow meth kit
4l80
50000miles!
Still running strong
Old 12-02-2006, 07:42 PM
LSs1Power's Avatar
2.) How much boost.
3.) How much rwhp.
4.) Transmission.
Thanks!
1) ATI D-1SC SDCE
2) 8psi 10psi and 13psi
3) 550rwhp(Dynojet) 554rwhp(Mustang Dyno) 630rwhp(Mustang Dyno)
4) T56
5) No
6) 4-5K miles
7) Nop.... Compression and Leak down test are great.
Old 12-02-2006, 07:45 PM
ninetres's Avatar
2.) How much boost.
3.) How much rwhp.
4.) Transmission.
1. Custom T76gts front mount
2. 10 psi
3. 653 and only spinning to ~5000
4. Stock T-56 w/ ram HD. About to install my rossler TH400 and fuddle 3200
5. No meth.
6. ~2500 miles
7. No symptoms
6.
Old 12-02-2006, 07:47 PM
ninetres's Avatar
Originally Posted by Jamesbond2509
6L iron block
12lbs
HP - TBD
Snow meth kit
4l80
50000miles!
50,000 miles at 12 psi and you haven't had your car on a dyno yet.....sniff sniff.......??????
Old 12-03-2006, 02:20 AM
Mr_president's Avatar
1.) How much boost.
2.) How much rwhp.
3.) Transmission.
4.) Meth, yes or no.
5.) How long you've been running this... approx miles.
6.) Any symtoms of engine failure so far?[/COLOR]
2. 8 psi
3. 550 and 547 with t56, i havent dynod the th-400 with fuddle 3600 stall
4. TH400 and fuddle 3600
5. devils own meth injection, havent been back to redyno with the neth....
6. 6000 miles
7. runs great 10.60s in the quater on hossier QTPS....time for a couple more pounds and 10.00/9.99
Is anyone doing 9s on the stock bottom end boosted?? (with out a Gutted tin can?)
Old 12-03-2006, 07:30 AM
Mark98SS's Avatar
1. D1SC 8Rib FMIC
2. 7psi
3. 504 on the T-56 - not back to dyno with the A3
4. TH400/3500TC
5. No
6. 2000 mile/50passes
7. No
Old 12-03-2006, 08:51 AM
ZDOG's Avatar
1- d1sc
2- @8lbs
3-470 rwhp
4-stock m6
5-no
6-400 miles lol!
7- my cold start idle sucks!
Old 12-03-2006, 09:18 AM
LS1Tech Sponsor
Superman09's Avatar
great results guys!
Also... if you forged guys ran your set up on stock bottom end or have before with other set ups, post up the info and how long it lasted! Thanks~
__________________
Old 12-03-2006, 03:17 PM
1320's Avatar
1. my own kit
2. 14-16 psi with 76 turbo rearmount
3. 550-650 rwhp depending on tune and fuel
4. th400's
5. water/meth or straight meth on pump gas (91)
6. the 99 around 10000 and my 98 is at 12k miles, both have 75k miles or more on em.
8. no down side, othe rthen the baby sitting and fixing small problems like leaks, either boost or exhuats.
Old 12-03-2006, 03:24 PM
LS1Tech Sponsor
Superman09's Avatar
how about some guys that lost their stock motor with boost.... what is your info?
__________________
Old 12-03-2006, 03:41 PM
Mark98SS's Avatar
Originally Posted by ZDOG
1- d1sc
2- @8lbs
3-470 rwhp
4-stock m6
5-no
6-400 miles lol!
My cold start idle is awful too, sounds like a prostock cam or something for the 1st minute.
Old 12-03-2006, 04:03 PM
SSilverSSurfer's Avatar
good thread superman09...i could see this as a sticky , keep it coming guys
Old 12-03-2006, 04:21 PM
jamesSS's Avatar
i agree. i would also like to see how many miles are on your guys motor total(not just boosted miles). is there any 500+ hp 100K miles motors on here?
Old 12-03-2006, 04:41 PM
how many of you guys went from extreme H/C/I combos to FI on a stock motor? am i setting myself up for disaster?
Old 12-03-2006, 05:00 PM
mcmillion's Avatar
I have 120k total miles on my car
1) t76 front mount
2)10 psi
3)560 rwhp (mustang)
4)t-56, spec 3
5) no meth
6) 1500 miles
7) no (knock on wood)
Old 12-03-2006, 05:41 PM
The miles keep piling up being a daily driver. The EFiLive road dyno showed 525rwhp before the 2.8 Blower install. I plan to dyno next spring when the 408 is installed.
Old 12-03-2006, 10:45 PM
pwrtrip75's Avatar
2.) How much boost.
3.) How much rwhp.
4.) Transmission.
Thanks!
1- turbo, 5.3L w/ 6L heads = 8.6:1 compression
2- 15psi
3- 600ish
4- TH350
5- no meth
6- maybe 50 so far
7- running perfect.
My shortblock came from LKQ on ebay, im sure its got a ton of miles on it.
Quick Reply: Boosted Stock Bottom End guys IN HERE!
