Is this coolant in my oil? Pic inside
Old 12-27-2006, 04:19 PM
Fire-formula 93's Avatar
Default Is this coolant in my oil? Pic inside
Just checkin oil level today, opened oil cap for the hell of it and found this. Sorry for the blurriness but you can see what is going on, it looks like cheese.
I just changed the oil 1 week ago and old oil was fine.
Is this coolant in my oil? Why would coolant be in my oil?
Old 12-27-2006, 04:25 PM
fastest94v6's Avatar
GULP!!! has you car overheated? I would say head gaskets according to your description.
Old 12-27-2006, 04:38 PM
92SilverSHO's Avatar
Do you do short trips a lot?
Old 12-27-2006, 04:42 PM
YoMommasTA's Avatar
pretty normal for the ls1 engines becuse the cap is not vented in any way.It the coldest part of the engine and tends to collect moisture.If you are not loosing any coolant you are fine.I've seen this so many times.
Old 12-27-2006, 04:46 PM
Yes I do a lot of short trips, very rarely do I go for a long drive. Everywhere I need to go is less than 3 miles away from my house. The car has not overheated at all (knock on wood). I will also check the coolant level as soon as my car cools down a little.
Old 12-27-2006, 04:49 PM
YoMommasTA's Avatar
you're fine
Old 12-27-2006, 05:04 PM
2001NBMZ28's Avatar
I'm confused, you changed the oil a week ago...was the cap clear then? Thinking condensation on the cap should be more of a white milky substance?
Old 12-27-2006, 06:38 PM
RUDE SS's Avatar
That crap is from improper venting on gms half. If you had coolant in your oil your oil will look like a milkshake
Old 12-27-2006, 10:45 PM
Camaroz's Avatar
Theres your answer Lots of short trips = condensation buildup
Old 12-27-2006, 11:51 PM
2000LS1TA's Avatar
Just condensation, don't worry about it. Take that car out and hammer it!
Old 12-28-2006, 11:19 AM
Thanks for the good news guys.
Old 12-28-2006, 12:03 PM
gyrene2003's Avatar
remember, doctors orders, Hammer it!!!!!!!!!
Old 12-28-2006, 01:27 PM
98-LS1's Avatar
Mine does the same thing, I only live about a mile from work so short drives tend to build condensation. It scared me at first too, it seems the catch can thing helped suck the moisture out. Ever since I installed it there has been no more pasty oil build up crap on the fill cap.
Old 12-28-2006, 01:43 PM
burnrubr88's Avatar
looks like just moisture. kinda surprising though i haven't seen that much on a GM but used to see it all the time on chrysler's
Quick Reply: Is this coolant in my oil? Pic inside
