Parts for sale!!!
Old Dec 28, 2006 | 06:45 PM
Justa Z's Avatar
Default Motor and trans
LS1 5.7 block has 40k on it and the heads cam and springs have less the 5000k. The heads are TEA stage 2, and the cam is a custom grind 228/232 .575/.585 112 LSA, comp 7.400' chrome moly pushrods, the motor made 400rwhp through a 4l60e and a 4400 stall, i am including full motor - powerstearing, flexplate,and pully, i have a stock ls1 intake if you want it just no hardwear for it. This motor runs great and ran it in october before i pulled it to put in a different camaro. The motor is still in the car so i would need to pull it out. The heads and cam alone were $2200. I would like to get $2500
I have a th350 trans it is a foward valve body and also have a Hurst Quarter Stick Shifter, and a crome moly driveshaft with it, i will take $600 if picked up (north west burbs of chicago) the trans was used with a neil chanch 3200 converter in a lt1 setup that was around 280 rwhp, the trans worked fine before the motor was pulled and sold. It is out of BadLt1's camaro. I also have the bmr trans crossbar i will add for $50
Digital Nx progressive controller with a palmpilot = SOLD
30 lb injectors- bought off a buddy but i need the 42's for my 408- soldshiped these are used i would guss about 5000 miles before he totaled his car
Steel Nitrous drive shaft(bought from speed inc $380 new, looks new) 4l60e to a 9"= $180 SALE PENDING
Mufflex 4" exaust with a single dump, 1000 miles at most= SOLD will come with a extra dump, i took off the muffler and just dumped it before i ran open headers, so i have no use for it
Please pm me with ?'s Thanks
Old Jan 1, 2007 | 01:44 PM
camaro383's Avatar
do you have any pics of the progressive controller and the features of it..
thanks
may email is mateoss325@aol.com
Old Jan 2, 2007 | 11:08 AM
Justa Z's Avatar
i can take some pics, it can do almost every thing. Theres a spot to hook up a transbreak if you want to spray off the break, it logs your runs, very easy to adjust through the palmpilot. It will work great for 6 speed cars too
Old Jan 4, 2007 | 09:50 PM
Justa Z's Avatar
progresive controller sold!!
Pending sale on injectors
Old Jan 4, 2007 | 11:27 PM
spartyon's Avatar
Specs on tranny please. Any pics to? I live in northern burbs so pick up not a problem. Convertor go with it? I need a 3200 anyway so this would be perfect. Manual/Automatic?
Old Feb 10, 2007 | 07:28 PM
Justa Z's Avatar
NO CONVERTER. it is a stock rebuild with a **** kit and about 5000k miles, trans is painted red
Old Feb 11, 2007 | 10:58 PM
Justa Z's Avatar
TTT. Good Stuff guys
