Aftermarket Goodies: B&M, Holley TB, Rollmaster, Custom Cam...
Here are a few things I have left for sale. Please PM me with questions, thanks!
- Comp Cams Custom: 230/248, .626"/.632"(1.8 Rockers), 112+2 LSA: Used this cam in my 427 LS1 with LS7 heads. It was an AWESOME cam. Although the engine was never tuned to its full potential, this cam is a lot of fun. It is designed to provide awesome midrange power to generate power "under the curve." It idles nicely at 650rpm with some mean sounding lope. It also has great street manners. Only has 1667 miles on it. SOLD.
- B&M Ripper Shifter: This is a great shifter, huge improvement over stock. Has about 20k miles on it and still works great! No signs of wear whatsoever. Comes with the adjustment plates, bolts, and a shift ****. SOLD.
- Holley 90mm TB: Has 1667 miles on it also. Has a small scratch on the top, other than that it looks amazing. Works very well, also comes with a throttle cable bracket to fit LS2/7 manifolds with cable operated throttle. $360 shipped.
- Rollmaster Double-Roller Timing Set: About 6k miles on it. Great set-up for cammed cars. This is the heat-treated version, adjustable, and comes with the torrington bearing. Also comes with spacers and longer bolts for the oil pump. SOLD.
- AC Delco Camshaft Position Sensor: Has about 55k miles on it. I bought a new one because I thought it was causing a problem, but it wasn't. $25 shipped.
