LS1 Lid under Stock Camaro Hood
Old 01-06-2007, 05:31 PM
the_merv's Avatar
Default LS1 Lid under Stock Camaro Hood
Got it finally...
For who that asked, here are the pictures. It clears by about 1/4 to 1/2 inch from the Hood with this setup. I had to cut a little out of the bottom of it.
To be honest, unless you have the patience, this is a pain in the *** project. The plastic on some of the pieces decided to break, so that had to be fixed as well as setting all of it up. It is just alot of little stuff that had to be done, but it all clears. The Radiator was set back a couple of inches, that is the key to getting this in one of our cars. Anyone with the Ram-Air Hoods have no problem with the actual LS1 Radiator shrouds, but for the Stock Hoods, you have to move the Radiator back.
The Hood is Red, eventhough the pic shows like it's purple.
Old 01-06-2007, 06:54 PM
daniel6718's Avatar
what did you use between the maf and the t/b
Old 01-06-2007, 07:11 PM
hyperzone's Avatar
thankyou, thankyou.... Thanks for the pics merv but, what about under your fab'ed metal piece and lid? any cutting involved there?
Old 01-06-2007, 09:58 PM
the_merv's Avatar
SLP Bellow for Ram-Air Fire Bird. I cut it up in the front of it about 3/4 inch shorter.
I cut out the cross-support as wide as the Lid, you can see it where the Lid sits up against. It's cut to where it rests in there. Then I did a little trimming on top of the Radiator. It clears the stock Hood no problem, and it sounds like a jet in the front of it, it's loud. It still pulls hard, in 3rd it will suck you into the seat, and that was at a 3500RPM punch. It pulls all the way up to 6100RPM where it shifts.
Old 01-06-2007, 11:54 PM
Revelation Z28's Avatar
would the SLP lid work too? or will it rub? cause it even rubs the SS hood.
man, you shouldda painted that sheetmetal before putting it on
Old 01-06-2007, 11:58 PM
Lethal Z's Avatar
Great pics, you got ***** man. Set up looks good.
the_merv's Avatar
SLP Lid will work on my setup, I wanted an SS Hood, but this works. The SS Hood will be close, if not too tight of a fit.
That's Stainless Steel, good stuff
It brightens up the Engine Bay a little bit..
Old 01-07-2007, 12:02 AM
the_merv's Avatar
I wouldn't say just *****..alot of patience. This was a pain in the ***..but it's done clean, and it will hold together. The guys at work said it looks alot better. I have that Intake, it's a bit of a sleeper now..
Old 01-07-2007, 12:14 AM
landstuhltaylor's Avatar
what are you going to do about the hole in the hood?
Old 01-07-2007, 12:21 AM
the_merv's Avatar
What hole? That's part of the under-structure cut out of it, there is no more hole in it anymore. Looks like a bone stock LT1 Camaro now.
Old 01-07-2007, 12:22 AM
so only the stock lid will work with the stock lt1 hood?
Old 01-07-2007, 12:24 AM
the_merv's Avatar
That Lid there is the Granatelli Lid. All of the aftermarket ones are all the same, and will fit no problem.
Old 01-07-2007, 12:35 AM
im gonna do this instead of the moroso. ill sell my moroso to fund for the lid.
Old 01-07-2007, 12:37 AM
the_merv's Avatar
I got a big gain out of it, it pulls a hell of alot more in the high-end. I am goin to the Dyno in a week, so we will see. Then the Track opens up soon.
Old 01-07-2007, 12:38 AM
the one you first cut in the hood when the lid stuck out. i remember you covered it with a pseudo shaker scoop.
yea, mine pulls in the top end, but even more so since i did the stock air box de-facing mod.
Old 01-07-2007, 12:51 AM
the_merv's Avatar
I did that a long time ago.. this is totally different, it pulls like 5 times that, easily..
Old 01-07-2007, 12:52 AM
the_merv's Avatar
Yea, that's all gone now. I am just a regular red Camaro..
id like to either put the SLP lid, or the MTI clear lid when i do this...
Old 01-07-2007, 10:24 AM
SmokedOutZ28's Avatar
hey man i got a couple of questions.
How do you get the lid off now? Do you undo the sheet metal
Whats the clearance like now with the radiator & fans?? How far do they sit away from hoses & the waterpump and are there any cooling issues with it sitting back futher?
Did you use anything different to direct the air up into the lid?
Last can you take the lid off and post some pics of what it looks like underneath and how much cutting had to be done?
Thanks for the help im interested about doing this on my LT1 as well.
Quick Reply: LS1 Lid under Stock Camaro Hood
