So here's the game plan 00 Mustang + LSx + huge turbo :)
Old 01-08-2007, 07:31 PM
7 Second Club
Phil99vette's Avatar
Default So here's the game plan 00 Mustang + LSx + huge turbo :)
We just picked up the car for our new project and would love some feedback. The car is a 2000 Ford Mustang V6 auto with just over 100k. Its a single owner car, never seen a fender bender and is perfect in every way. Stole it for $400.
The swap... We're going to tear the car down to just the unibody and remove everything thats non essential for a fun street/strip car. Its going to recieve an 6.0 iron truck block stuffed with forged internals(w2w Mahle boost pistons/Pro-mod rods and 4340 4" crank) and topped with some decent heads. Custom made 1.75" headers will run to either an S95 or Precisino turbo 96mm with a 5" downpipe and twin tial 44mm gates. Transmission will be a powerglide with a dedenbear case and 1.80 straight cut gears, rear will be a 9" with ~3.50 gears. Outside will get a VFN 5" cowl hood similar to John Urist's mustang without the scoops and a 12" sheetmetal wing on the rear with chute. Inside will recieve a couple of race seats probably kirkey or so, some carbon fiber parts on the dash filled with autometer guages. Wolfe racecraft 10 point cage with window net, sub frame connectors will finish the interior. Dash will be stripped as much as possible but still leaving a factory appearance and a air to water IC will be hidden behind the dash. Street duties will be on a set of CCW 500s while at the track we'll use Weld aluma stars with 30 x 10.5" slicks and skinnies up front. Target weight will be around 2800lbs. How does that sound? The corvette will probably get a new milder motor to enjoy the sunny summer days.
Phil
Build List:
00 Mustang V6 5 speed:
Engine:
Iron Truck block 4.030
Lunati Rods
Callies 4" Crank
Mahle Boost pistons -32cc
ETP LS7 heads 72cc
GMPP LS7 Carb Intake
CR: ~8.5:1
Exhaust:
1.75" tube headers -> 2.5" crossover
5" downpipe
Turbo Setup:
Forced Inductions.com S95
Twin Tial 44mm Wastegates
Single Tial 50mm Blow off valve
4" Intake plumbing
1800hp Air to Water IC
Fuel system:
Custom tank
4 - Walbro 255 pumps on two circuits controlled by boost
160# injectors
ECU:
Big Stuff 3
- Dual Wideband
- Data logging capabilites
Front Suspension:
UPR K member
Custom UPR Control arms
UPR Castor/Camber CNC'd plates
Strange Struts
UPR Coilovers
Rear Suspension:
QA-1 Coilovers
Moser 9" narrowed 1.75"
- 3.50 prostreet gears
Wolfe Racecraft Upper/Lower control arms
Wolfe Racecraft Sway Bar
Wheels Tires:
Weld AlumaStar 15 x 3.5 with MT 26" Front runners
Weld AlumaStar 15 x 10 6" BS with MT 28" ET Drags
Cage:
10 point Wolfe RaceCraft
Pics:
Old 01-08-2007, 09:02 PM
Cop Car's Avatar
that is a steal. lets see pictures
Old 01-08-2007, 09:04 PM
Sandmann120's Avatar
Atta boy. Keep us posted on the progress. I wonder if truck manifolds would clear any on the aftermarket k-members? Might simplify the header situation somewhat. Sounds like a killer setup.
Old 01-08-2007, 09:06 PM
PRAY HRD's Avatar
how much power are you looking at making? remember, an aluminum block will take upwards of 1000+rwhp! just an idea. othewise, sounds great. unbelievable price too!!!
+1 on pics!
Old 01-08-2007, 09:07 PM
LSxChevelle's Avatar
Wow! What a steal!! Can't wait to see some progress...
Old 01-08-2007, 09:40 PM
MrDude_1's Avatar
sounds mild... why dont you pump it up a bit...
Old 01-09-2007, 07:10 AM
Turbo302's Avatar
Sounds like a COOL project
I've actually already started the same project last month at our shop with a 99' V6 Car. Been keeping it on the downlow so the local crowd doesnt catch wind.
We are most likely going to run a full built Rossler 4L80E w/transbrake to maintain overdrive.
Its a slow proceeding project we concocted up over last summer, but didn't get started until just recent.
Will keep an eye on your project, as great minds think alike
Tim
Old 01-09-2007, 08:35 AM
7 Second Club
The car is still in the trailer,. I'll snap some pics when I get it into the shop. I'm thinking 6-7 months to complete the project but only time will tell.
Old 01-09-2007, 08:36 AM
7 Second Club
I'll check, I was planning on making some simple headers, 90s down 90s forward into a collector.
7 Second Club
+1 on pics!
1200-1500 with the iron block. Depending on how funds go will determine alot of stuff.
Old 01-09-2007, 08:37 AM
7 Second Club
Tim
That sounds like a great project also, best of luck with it. I've talked to only one local guy and I've already had a handful of people ask about the mustang and I just deny it.
Phil
Old 01-09-2007, 08:57 AM
Ericbigmac83's Avatar
Just dont forget a big Chevy Powered sticker
Old 01-09-2007, 02:12 PM
LebaneseShowoff's Avatar
+1, "Chevrolet, the Heartbeat of America"
Old 01-18-2007, 10:21 PM
7 Second Club
Couple teaser pics of making the mold for the hood....
Old 01-18-2007, 10:24 PM
PRAY HRD's Avatar
Wow!!!!!!!!
good luck seeing outta that sucka! that thing is gonna be NASTY!!!
Old 01-18-2007, 10:33 PM
JRracing's Avatar
Built Ford tuff with chevy stuff. Thats what it should say Phil.
We want pictures...
Old 01-19-2007, 04:07 AM
jbk240z's Avatar
Talking
You had better install a periscope in the cowl to see over the hood. LOL, j/k
Old 01-19-2007, 04:43 AM
Posi12Bolt's Avatar
subscribed!!
Old 01-19-2007, 08:16 AM
7 Second Club
I'm going to lay another layer of glass and hopefully pull it off to start the body work to finish the mold. If time permits I am going to start the pattern for the sheetmetal rear wing. We've only got a week or so before parts start getting here so its gotta get done.
Phil
Old 01-19-2007, 11:40 PM
Cop Car's Avatar
bare carbon fiber hood
Quick Reply: So here's the game plan 00 Mustang + LSx + huge turbo :)
