Post-LCA install issue
Just got my UMI adjustable LCAs and relocation brackets on. Problem - the passenger side wheel sits about 1/2" farther back in the wheelwell, about 3/4" from the rear bumper piece. On the driver's side, there's about 1" between the wheel and the same spot on the bumper. Both LCAs were adjusted to within 1 or 2 threads of each other, and both were installed on the lowest hole of the relocation brackets. Do I need to jack the car back up, drop the axle end of the passenger LCA, and shorten it up more? Seems like there's another issue at play, because if both the LCAs are the same length, the wheel should sit in the same place in the wheelwell...
Originally Posted by logikal6785
equal length lca's + frame damage = diff meas.
Are you the original owner? Somehow someone might have tweaked the car and now ... =/
Everything was lined up with stock parts. I don't see why it's not with this stuff.
Going to pull the passenger LCA off tomorrow and stick the stock LCA up there, and see what I see. If the axle is pushed farther back, I honestly have no idea how to get it back to the stock location.
Most of these vehicles come factory with tolerances like you are seeing. The rear ends are never centered, front to back or side to side. Since you have adjustable lower control arms take advantage of them and adjust them until it is centered and correct the problem. If you lengthen the arm it will push the rear end back and if you shorten the arm the rear will go foward.
Hope that helps,
Ryan
Hope that helps,
Ryan
Hope that helps,
Ryan
Hope that helps,
Ryan
Once I got everything bolted up (SFCs too), took her out for a spin and DAMN. Hard to describe how it feels different in corners, but it just feels like instead of a floorpan made of cardboard, it's actually made of steel now. Significant reduction of torsional chassis flex in the corners. The LCAs and brackets definitely give the rear some more bite, too. Ride is a bit more stiff, but the suspension can crack my vertebrae going over cracks and bumps, as long as it does what it's supposed to
Excellent to hear and the way you took the measurement is perfect, I should have mentioned that as well, we never use the bumper because of that reason. The 1/8" you are seeing is great as well, you won't get it much closer then that.
Glad you like everything
Ryan
Ryan
Originally Posted by sobaka79
get some adjustable lower control arms, thats what theyre made for.
He has adjustable lower control arms.
Also, just because your wheels are centered (or not) doesnt mean that they are centered with the running gear. The only way to do that is with a 4-wheel alignment.
https://ls1tech.com/forums/showpost....00&postcount=5
