FS: Dual SPAL fans (Dual 11") already modified for F-body use.
Old Jan 27, 2007 | 02:59 PM
Avengeance's Avatar
Cool FS: Dual SPAL fans (Dual 11") already modified for F-body use.
I recently had to pull my radiator out of my SS because it had a leak. While it was out, and buying a new radiator, I have decided to try something custom for my cooling. I will not need these SPALs anymore.
They work great, fit perfect, and are already modified to fit the F-body radiator. Some of you may know these require some trimming and adding a top mount to work with our cars. This setup will work with a P1SC and D1SC... furthermore this works with a D1SC AND my 8 rib setup, which is what I have. It was tight but it worked just fine. Even in the CA 110* weather I was able to drive and not over heat.
From what Ive seen these retail anywhere from $250-$300+. WITHOUT being modified for a F-body.
NEW PRICE
$200 + shipping. Im located in CA.
I have had some transactions here with fellow LS1ers... feel free to search here. Also.. check out norcal-ls1.com (Avengeance) and 35thle.com (35TH LE) if you want more references.
THANKS FOR LOOKING!
Old Jan 27, 2007 | 04:26 PM
TS6's Avatar
TS6
What is the CFM rating on these fans?
I have a D1SC 8 rib setup on my car with the stock ATI shroud and another spal 9" puller fan added to it, but I need more fan. These look like the ticket. Do you have a part number?
Old Jan 27, 2007 | 04:59 PM
Avengeance's Avatar
The model # is SPA30102052. This dual fan is rated at 2780cfm. Thanks.
Old Jan 28, 2007 | 01:58 PM
Avengeance's Avatar
I know someone wants these.
Old Jan 28, 2007 | 05:10 PM
kawasakiklx's Avatar
PM where you are in CA
Old Jan 28, 2007 | 05:50 PM
Avengeance's Avatar
Sending PM.
Old Jan 28, 2007 | 06:34 PM
craparo's Avatar
will they fit with a mezeire ewp??
Old Jan 28, 2007 | 06:44 PM
Avengeance's Avatar
I dont see why not.. the EWP doesnt look to be anymore protruding then the stock pumps size and the dual SPAL setup is deffinately thinner then the OEM shroud/fans. Basically.. if the EWP will work with OEM fans then it really should be ok with the dual SPALs.
Thanks.
Old Jan 28, 2007 | 07:38 PM
Avengeance's Avatar
NEW PRICE
$200 + Shipping
