Cam,injectors,gears,fuel pump and harness.
Cam is a TR224 224/224,.565.565 on a 111.5lsa 6k and perfect condition
$275
30 Pound SVO Injectors with 7k on them, great shape.
$175 SOLD
Moser 9 inch gears.411 ratio with 2k on them perfect shape
$100
Walbro 255lph inline pump on car for 1 day,basically new.
$100
Casper ls1 hot wire kit.about 7k on this harness,works well with inline pump
$40
All parts are in Downtown Chicago. Will also ship. Parts are all in great shape and have no problems. Check my trader ratings. No worries here.
Alex
http://s124.photobucket.com/albums/p18/SPRAYED_01/
$275
$175 SOLD
$100
$100
$40
Alex
$100
is that the pump inside the tank? cause i have a stock 1997 Z28 and the pump is bad will this pump be ok on my stock ? if it even will work on my car?
$100
No this pump is not an intank. It is inline. It will work on your car,but i think you need to remove you intank pump because it would be a restriction.
Yes it will. It plugs directly into the stock harness and then to the alternator for max voltage. It also has leads for an external pump if you need them. Check it out on Speed inc web site. LS1SPEED.COM. Thats were i bought it.
