FS: NX Maximizer 2 Progressive Nitrous Controller - New'ish!
$460 shipped
Nitrous Express Maximizer 2 Progressive Nitrous Controller
Part # 15959 Cost $732 from Summit Racing recently.
Was hooked up but never used since never got the direct port finished hooked up.
Its in like new condition, ready to wire up and use! Includes everything I needed to hook it up and just uses your PDA or laptop to run it.
Heres a picture how it all came new. Looks pretty much identical, just all packed nice in a box.
Features:
* Dual Stage independent output channels (independent profiles for each channel)
* Time-based ramped delivery of nitrous and fuel (unique programmable delay and ramp times for up to 8 gears)
* RPM-based delivery of nitrous and fuel (unique programmable curve for up to 8 gears)
* Throttle-based modifier of nitrous and fuel (reduce nitrous delivery by up to 35% based on throttle position)
* LEAN threshold automatic “cut-off ” when using FJO Wideband system
* Programmable RPM trigger point and cutoff
* Programmable MAP cutoff (when using nitrous as an 'anti-lag' system)
* Nitrous pressure sensor input
* Built-in MAP sensor reads from vacuum to 48 psi of boost
* Gear detection for manual and automatic transmissions
* Inputs for arming switch, bottle heater enable switch, 2 trigger switches, throttle position, tach signal, nitrous pressure, and Air/Fuel Ratio (narrow or wideband)
* 2 configurable outputs for either: integrated bottle heater control, integrated bottle opener control, automatic N2O purge function, or status LED
* 2 ignition retard outputs
* Digital communication port for PC or digital gauges
* Easy to use graphic set-up menus and datalogging using Windows™-based PC
* High current 2-channel solenoid driver
* Available for on-line purchase.
I take paypal etc
Features:
I take paypal etc
