NIB Comp Cams: 2 to choose from
i have 2 new Comp Cams that i bought with a couple of others and have chosen one to go with and need to sell the others. one is a 240 / 244 with 608 / 612 lift on 112deg lobe seperation. the other is a 244 / 244 608 /608 lift on 112 lobe seperation.
i also have a slightly used 224 /224 585 / 585 lift on 110degs of lobe seperation.
300.00 for the new ones a piece and 200 for the used one.
i was wrong on the specs on the 224 cam. it has 563./563. lift and 112deg lobe seperation with nothing added. sorry for the confusion, i have went thru so many cams latley i forgot exactly what i had. thanks!
Originally Posted by sampson01
would the used cam be usable with the stock springs and lifters ... and also what did it give you for a gain
Springs = no | I would highly recommend a set of aftermarkets of atleast the comp 918's. A set of ls6 springs will handle the cam though.
This cam has been used in full bolt on setups netting at or above 400 for m6 cars and at or above 380 with a4 cars.
my source at comp cams didnt have the cam card for this cam but ask what info you needed and he could give it to me. and connexion is exactly correct, this cam put down alittle over 390 in an auto.
