S60, 12 Bolt, Ford 9 inch sale at DLS
S60's starting at $2450.00 "Strange just increased their housing prices for 2007."
Moser 12 Bolt starting at $2250.00
Ford 9 inch start at $2150.00
All assemblies built in house
Our S60 assemblies come starndard with 35 spline axles and you have your choice of differntial. Either a Power-loc, Truetrac, add $185.00 for Detroit locker. Just about any gear ratio offered from OEM to Strange. 1350 pinion yoke with straps and stock steel cover, a TA will fit but you must have a tubular pan hard hod to clear. Driveshafts good for 1000 hp are $345.00 shipped. 3 shanel ABS is no extra charge but ad $125.00 for 4 chanel prep for your stock rings and brakes.
Moser 12 bolt housing and axle package come with 33 or 30 spline axles and your choice of Eaton clutch style or Truetrac differential. Your choice of pinion flanges, either one to accept your stock driveshaft or a 1350 series your choice at no extra charge. Any ratio that US gear or Motive produces, pro gears add $185.00. 3 chanel ABS add $50.00, 4 chanel add $125.00 to accept your stock rings and brakes. TA cover add $137.50, chrome cover comes with package.
Moser Ford 9 inch housing and axle package come with a Strange S casting, Daytona support, any gear ratio, Truetrac or Detroit locker in 31 spline, add $125.00 for 35 spline Detroit locker. 1350 pinion flange standard and we use all Timken bearings. 4 chanel ABS add $125.00 to accept your stock rings and brakes.
*DLS 4 box special will not require any added shipping charges*
We weld on BMR swaybay brackets on all of our assemblies that we build in house to help your install be as easy as possible. Sorry we can not weld on relocation brackets, they need to be welded on after you have the assembly installed in the car. Average truck freight is $175.00 if shipped to a business, Fedex requires a special lift truck for residential deliveries and they add $100.00 to the bill. You may pick up at fedex depot if there is one in your area.
Please PM here or e-mail me personally at www.drivelinesolutions@yahoo.com if you have any more questions.
Please leave a detailed message if you get our answering service.
Our 4 box special will come in 4 separate pieces, the Moser housing and axle package with TA mount and we assemble the center section to your specs. and ship that to you with all of the hardware needed to assemble it yourself. You will need to press on
a set of axle bearings and reuse your stock brake backing plates. You will also need a swaybar adapter, we recommend the Spohn unit since it bolts on easily.
Originally Posted by JZHeyde
I sent an email last week...still no response.
whats the deal???
-Jamin
whats the deal???
-Jamin
Scott @ DLS
Originally Posted by xtremetrans
Do you sell housing and axle packages for 9in or 12 bolt? If so how much? I need it with 4 channel abs.
Yes we do sell seperate components, a Ford 9 inch housing and axle package preped for 4 chanel stock rings is $1100.00 shipped. You can get those with any spline count as well.
Scott @ DLS
Originally Posted by Scott@DrivelineSolutions
TTT, Strange pricing increase for S60 housings.
Originally Posted by SS14PSI
When does that take effect Scott? It doesn't affect me does it!? And a big TTT for Scott....I can't wait for my S60. I just ordered a slew of UMI stuff from Byunspeed to go with it too!
Nope, yours and one other assembly going to MO. will still be at the old pricing. My supplier informed me after I ordered these last 2.
Scott is great to deal with, I have bugged him quite a bit the past few weeks and he is always willing to help me out. I will be calling you after I break this stock driveshaft Scott.
-Dustin Wayne
-Dustin Wayne
