Katech LS6 ported oilpump $110 shipped
These are the cheapest prices will get, Im done with this project, but Ill keep it if I dont get what I need out of it.
ENGINE:
-LME built 370
-Lunati crank
-Lunati 6.125" Pro Mod Rods
-Wiseco 25cc dish pistons
-Hell Fire Rings
-Clevite rod,main, and cam bearings
-Custom 23x/23x turbo grind Cam Motion cam
-Crane Hyd. Roller Lifters
-Roll Master double roller w/ torrington bearing and nitrided gears
-Felpro head gaskets
-TEA Stage 3 AFR 205 heads
-flow 343 cfm @ .600 lift
-same port job as heads on W2W record holding LS1 TT motor
-Jesel SS Shaft Mounted Rockers
-Comp Cams 921 springs
-105mm Accufab throttle body
-105mm Wilson Manifolds Elbow
I have right at $15,000 in this longblock, Ill take $$8500 will half shipping.
TRANNY:-FLT fully built 4L80E built to support 1350 RWHP
-Fuddle Extreme Heavy Duty 4L80 3800 Torque Converter
I have $5500 in the tranny and 2 months of wait time and I believe around $850 for the torque converter, so Ill take either $4250 for the tranny and $500 for the converter or $4500 for both. Ill help on shipping as well.
FORCED INDUCTION: -Custom Twin Turbo with dual ball bearing 67mm turbos, Tial 44mm wastegates, FMIC, have to see what else comes with this. Have to also see how much I have in this. We'll say $4250 for what is listed right now
COMPUTER SYSTEM:
-Top of the Line Big Stuff 3 will control this beast. It has all data acqusition for tranny as well as motor.
-E Boost 2 boost guage
I have $4000 in these, Ill take $2875 for both or $2450 for BS3 and $475 for EBoost2.
I also have a partial fuels ystem for this with -10 and -8 AN lines, fuel pump, fuel filter, and all Russel fittings. $600
I have some misc parts like 1 set left of 4 dimpled and slotted rotors for $150
I have those Breatheless Performance projector headlights: $575
I WILL MAKE A PACKAGE DEAL, WILL TRADE FOR CERTAIN THINGS
I WILL TAKE $25,000 for the whole package, thats $3550 for a complete running 98 Trans Am WS6 with a built 4L60E, cammed, ported heads, ls6 intake 6.0, some suspension, $1000 projector headlights, and that is rediculous, but it needs to go. No, I will not sell the car for anywhere close to $3550 seperately so please dont ask.
ENGINE:
-LME built 370
-Lunati crank
-Hell Fire Rings
COMPUTER SYSTEM:
long block is not in car, brand new, nothing has ever been run, paperwork is there, I think its a 8.x motor, and I have the paperwork to the heads at the house, Ill give u the cc size when I get home.
Yeah, where are you located? What is the exact compression ratio? How big are the intake runners and combustion chambers? Does is come with an intake, or just the elbow & TB? Thanks!
Here is the info on the heads:
Mill heads up to .10(66cc)
2.080' Intake valve 4.900
1.600 Turbo Special Alloy Exhaust
1.300" coated dual spring .650 lift
1.220 Titanium spring retainer
.570" spring cup for TEA gold spring
