Megasquirt I / Stimulator / Harness FS
Old Feb 27, 2007 | 10:43 AM
350SS's Avatar
Default Megasquirt I / Stimulator / Harness FS
SOLD!!!!SOLD!!!!SOLD!!!!
Up for grabs is a Megasquirt I 2.2 board ECU http://www.diyautotune.com/catalog/m...unit-p-34.html
simulator http://www.diyautotune.com/catalog/m...unit-p-33.html
computer cable for ecu to laptop connection http://www.diyautotune.com/catalog/m...thru-p-35.html
And a harness that I put together for use on a small block Chevy engine but can be adapted to many configurations.
Asking price for package: SOLD!!!!SOLD!!!!SOLD!!!! I have feedback on Ebay (username maxcornelius) so that you feel comfortable with the transaction. I accept paypal as well.
Here are some of the highlights and features of the MS ECU:
Onboard MAP sensor for NA or boosted engines up to 21psi!
Speed density or Alpha-N.
Use High Impedance Injectors or Low impedance with resistor pack inline
Compatible with output from narrowband and wideband O2 sensors.
Log data on your laptop for later analysis.
Tuning software is free for download and regularly updated with new features.
Open Source design - all code and hardware information is available online.
Includes proper female DB37 connector and shell for your wiring harness.
Ignition Control, distributor-based and distributorless (DIS) systems
12x12 Volumetric Efficiency (VE) and Ignition Tables
Closed loop boost control
Rev limiters
Shift Light control
Water Injection control
Knock Sensor Input
The Stimulator board allows you to fully bench-test all standard inputs and outputs on your MegaSquirt unit. It will apply power to the MegaSquirt ECU and allow you to simulate engine sensor inputs such as the ignition system RPM signal, the Intake Temperature Sensor, the Coolant Temperature Sensor, Throttle Position Sensor and the Oxygen Sensor. You can manipulate these signals via the potentiometer ***** on the stimulator to simulate different engine running conditions.
I used this to control my supercharged engine in my Chevy truck. I have since taken off the supercharger and gone back to the factory computer so this setup is no longer needed and is in perfect working condition. Please PM me with any questions or offers. Thanks!d
Additional information can be found at:
http://www.megasquirt.info/
http://www.msefi.com/
Old Feb 28, 2007 | 10:02 AM
350SS's Avatar
Bump...
Old Feb 28, 2007 | 05:39 PM
350SS's Avatar
open to offers...bump for the afternoon.
Old Mar 1, 2007 | 09:14 AM
350SS's Avatar
lowered price...ttt
Old Mar 1, 2007 | 05:54 PM
boomtubes05's Avatar
pm sent
Old Mar 1, 2007 | 07:31 PM
350SS's Avatar
pm returned
Old Mar 1, 2007 | 08:21 PM
350SS's Avatar
sold!!!!sold!!!!sold!!!!
