grinding calipers for weld draglites?
Old Feb 27, 2007 | 04:37 PM
indigo28's Avatar
Default grinding calipers for weld draglites?
anyone know of any local dfw shop that can grind them or will grind them for some draglites to fit without rubbing? and at a fair price?
Old Feb 27, 2007 | 04:44 PM
nickdotcom's Avatar
do it yourself
1. find were they rub
2. grind that off
3. repeat until they fit
Old Feb 27, 2007 | 04:55 PM
FungusMungus05's Avatar
Originally Posted by nickdotcom
do it yourself
2. grind that off
Yup, it's no biggie.
Old Feb 27, 2007 | 05:15 PM
skipperbisket's Avatar
i'm glad i never had to do it personally, one of my buddies did it at my shop once, took a couple hours of trial and error. i guess with the right tools it might be easier but with the big huge grinder we had it wasn't that great.
Old Feb 27, 2007 | 06:25 PM
SiL3NtXWS6's Avatar
it's not fun, that's a fact.
Old Feb 27, 2007 | 09:45 PM
no_more_z28's Avatar
funny cuzz I did it in less then an hour with no problem, does'nt take damn scientice to do just common sense....
1. very easy
2. very easy
3 takes a dumb *** to f@#k it up...
Old Feb 27, 2007 | 09:56 PM
Mike96z's Avatar
alright, I need to do the same thing, grinded with 80 grit for an hour and still dont fit. Wat is the best grit for this no more z28 since its SO EASY LOL
Old Feb 27, 2007 | 10:45 PM
SiL3NtXWS6's Avatar
1. very easy
2. very easy
There's no way man. I find it hard to believe it only took you LESS than an hour. Aren't LT1 calipers different than LS1s though?
Old Feb 27, 2007 | 10:46 PM
SiL3NtXWS6's Avatar
You don't sand man. You grind. With a grinder + grinding wheel. I feel kinda sorry for you though.. sanding with 80 grit-
Old Feb 27, 2007 | 11:21 PM
Cantalope Kid's Avatar
Yep LT1 calipers are different than LS1 calipers...especially the part where you DON'T need to grind LT1 calipers to make them to fit 15's. With 15's you can either do the swap to LT1 calipers OR grind you LS1 calipers...I can't believe someone used 80 grit sandpaper...you must have GUNS for arms by now bro. hahah! Grinder will make easy work that of that metal and give you an excuse to paint them up all nice too.
Old Feb 27, 2007 | 11:26 PM
Pavlock Performance's Avatar
theres a right up somewhere to help you out and polish them if you feel lost. easy though but a big time consuming pita.
Old Feb 28, 2007 | 12:53 AM
Aerospace Drag Brakes FTMFW!!!!!
Old Feb 28, 2007 | 04:22 PM
Mike96z's Avatar
Sorry but I said nothing about sanding, I have an angle grinder and YES they have different grits, i had 80, so im going to 36 grit next time. As for the LT1 calipers, LT1 calipers dont need grinding @ all. 1/8 spacer in front, 1/4 in rear and bolt right up.
Old Feb 28, 2007 | 06:05 PM
greatwhite1's Avatar
use a grinding wheel then finish off with the 80 grit. Thats what I did and looks good
Old Feb 28, 2007 | 06:54 PM
Mike96z's Avatar
yea im doing his calipers lol, well get it done tommorow, went and bought some heavy duty 36 grit grinding wheels
Old Mar 1, 2007 | 05:42 PM
Mike96z's Avatar
just got it done, **** took forever.
