View Poll Results: yella terra or harland sharp
yella terra
96
51.89%
harland sharp
89
48.11%
Voters: 185. You may not vote on this poll
yella terra vs. harland sharp..
Old Mar 4, 2007 | 07:04 PM
ls2 bait's Avatar
Default yella terra vs. harland sharp..
which ones do u prefer and why?
Old Mar 4, 2007 | 07:59 PM
SStheBest's Avatar
i have the yella terras...i already had one break..but i think i know y.....uhhh one has needle bearings, one doesnt......just my .02 forged aluminum isnt really for longevity..kinda meant for weekend cruisin; racin
Old Mar 4, 2007 | 09:52 PM
ls2 bait's Avatar
which ones uses needle bearings? i know nothing about them honestly...
Old Mar 5, 2007 | 01:46 PM
marv's Avatar
<- voted HS...but I've heard mixed reviews on both of them.
Currently I'm running the HS 1.7s and they've worked fine...
I think it's just a matter of preference...
Old Mar 5, 2007 | 04:52 PM
Ryan02SS's Avatar
This is false. Both YT's and HS's use needle bearings around the trunion. There is nothing wrong with forged aluminum for longevity. Simply look at the Crane gold race rockers that are forged aluminum. They've been around since the 1960's and are still one of the best on the market. I have had my original YT's since 2003 with no problems. They are a very stout shaft mounted rocker setup. No valvefloat problems and they quieted down the valvetrain noticeably. HTH
Old Mar 5, 2007 | 05:00 PM
Patrick G's Avatar
LS1 Tech Administrator
Yella Terra has stepped it up a notch with their brand new Ultra Light shaft mounted rockers. Part number 6645. They are much lighter than the old Yella Terras. Most of the weight is centered around the trunion. The roller tip is super light. A few people on the board are running them. I should be running some before the end of the month!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 5, 2007 | 05:19 PM
ls2 bait's Avatar
good to know-i heard that they switched to a better design and the harlands where a bit heavy over the spring.
Old Mar 5, 2007 | 06:44 PM
cowboysfan's Avatar
I got me some YT at home waiting to be installed, I'm out here in the dessert.
fuerzaws6
Old Mar 5, 2007 | 07:25 PM
Order 66's Avatar
harland
Old Mar 5, 2007 | 07:28 PM
jub jub's Avatar
Both are excellent rockers but I chose YT because they were slightly cheaper and they have been redesigned to eliminate the weight over the nose. They are quiet, beefy and just a good all around rocker.
Old Mar 5, 2007 | 07:31 PM
mike#9's Avatar
I have the Yella Terras and have had no problems since they went in back in 2003.
Old Mar 5, 2007 | 08:23 PM
Cobra4B's Avatar
I've got the newer ultra light design... my stocker had 70k on them and I wanted to get rid of the needle bearings. Spins to 7k w/o issue... power levels off at 6500.
Heres some pics, almost too pretty to put the valve covers on...
Old Mar 5, 2007 | 08:39 PM
Racinbabycakes's Avatar
Yellas and love'm
Old Mar 5, 2007 | 10:48 PM
marv's Avatar
I will add that I had to grind on both sets of heads I've had to get the Harland's to clear...both were GM castings that had been CNC'ed...perhaps that was the problem.
However you look at it, grinding on your motor isn't any fun...
Old Mar 6, 2007 | 12:22 AM
Grimes's Avatar
Any other ppl with experience with the new yella terra design?
Old Mar 6, 2007 | 01:32 AM
studderin's Avatar
I've put the new style on 2 builds now. They have a lot of little improvements as already listed. Also have a much larger paired trunion, then the thin dowlpin HS. They should have less deflextion, witch is better for getting max lift for power. And better on the heads for guild life also.
Just some dyno pulls for winter, but see no issues. We'll be useing them over HS now.
http://i2.photobucket.com/albums/y11...n/P1010075.jpg
Old Mar 6, 2007 | 05:29 AM
SStheBest's Avatar
the only reason one of my YT's broke was it got starved of oil....my car has ring issues...and i have to monitor that more than anyone EVER should....but untill i pay it off i wont have the money to tear it down....plus i figure if i go in there i might as well put somthin worth while back in it
Old Mar 6, 2007 | 01:12 PM
2003torch's Avatar
Does anyone know what the new lighter YT weigh? As a pair or whatever. If someone has these ready to install and can weigh then first that would be great.
Also what lift ratio off the seat and at full opening if anyone knows.
Mark
Old Mar 6, 2007 | 01:58 PM
bradster's Avatar
Will the YT's work on Trick Flow heads
Old Mar 7, 2007 | 03:56 PM
00LS1SS's Avatar
Bump, I would like to know as well.
