TSP 231/237 users inside!
Old 03-05-2007, 01:23 PM
ICRAZY6's Avatar
Question TSP 231/237 users inside!
I'm getting ready to purchase my heads and cam for my car once the trans issue is taken care of. I might be able to get a good deal on a TSP 231/237 cam. The car will be mostly street driven, want 420+ rwhp and might see a few track runs. My question is will this cam give me what I want? I'm thinking MTI Stage 2E, Patriot Stage 2, or TSP 5.3 Stage 2 heads for my set up. Kind of new to heads and cam so would like some Good edvice on what I should use in my set up. TIA
Steele
Old 03-05-2007, 01:33 PM
SSpdDmon's Avatar
I've got a very similar cam (232/238) and put down the numbers in my sig with ported 241's.
Old 03-05-2007, 01:34 PM
Z'mnypit's Avatar
Steele
I tuned a TSP 231/237, Patriot stage II LS6 heads, combo that did 417hp in 97* weather, no UD pulley. The AFR was a little sketchy on it but a little longer and I could have gotten 5-10 more out of it. Id highly reccomend that setup up.
Justin00SS's Avatar
I'm going with that cam on the stocker heads.
Looking for 400+
Old 03-05-2007, 01:35 PM
ICRAZY6's Avatar
How is the drivability with the cam? Thats the hp I'm looking for. Do you know if its possible to spray 150hp shot with this cam and one of the heads I'm looking at?
Old 03-05-2007, 01:39 PM
ICRAZY6's Avatar
Up, not sure how much longer the deal will last.
Old 03-05-2007, 01:48 PM
Z'mnypit's Avatar
The car I mentioned also had a NX single nozzle kit, did 527hp on the bottle. The drivability is excellent if tuned correctly. His starts right up idles fine and runs real good.
I ran that cam in my stock headed motor for a long time with a NOS wet kit and I was cutting 11.2's on the bottle.
Old 03-05-2007, 01:58 PM
ICRAZY6's Avatar
Cool. Thanks for all the help. Anyone else like to get a word in on the subject.
Old 03-05-2007, 02:07 PM
Dr. Jeckel's Avatar
This is my friends setup. This is about 2 years old, so the newer version heads will yield better numbers. It is an 99 M6 with stage 3 cartek clutch and all supporting bolt-ons. He was dynoing on ZR1 17x11 wheels also.
These were his exact words;
"The cam is a 231 237 .595 .598 @ 112. I have the patriot stage II heads.
It made 417 rwhp and 390 torque. On 150 it made 592 rwhp and 660 torque. All throurgh my 9" with 389 gears."
Hope this helps ya out
Old 03-05-2007, 02:20 PM
ICRAZY6's Avatar
Thanks DR. Any other A4 guy using this combo?
Old 03-05-2007, 02:35 PM
SSwt00SS's Avatar
did they have to flycut the pistons for PVC clearance? were the Patriot heads the 59cc or the 64cc chambers?
Old 03-05-2007, 02:44 PM
Z'mnypit's Avatar
I installed them and no fly cutting required. 2.02/1.60 valves I believe they were. Clearence was real tight. Id have to double check its been so long since Ive done that. I also think it was the 59cc chamber, the CR was right at 11.3-1 with the stock gasket.
Old 03-05-2007, 02:56 PM
SSwt00SS's Avatar
if you could to that and get back to me, i'd appreciate it. I have the Stage II from Patriot w/the 2.02/1.57 59cc chambers and like the 1st guy, i want to go to a bigger cam. either this one, or a Torquer v2. i started a thread about flycutting for a bigger cam and got mixed replies...TIA
also did you install straight up (dot to dot) no advance, or retard? i'm right about the 11.3-11.5 CR at the moment after installing these heads and my current tune back in early jan of this yr...
Old 03-05-2007, 03:07 PM
ICRAZY6's Avatar
So what size chambers are needed to run this cam?
Old 03-05-2007, 03:16 PM
SSwt00SS's Avatar
i believe that's really personal preference. I went with 59cc chambers to get a little more of a higher CR (factory is 10.1:1). Patriot welds up their heads, so they do not mill down thier heads like other manufacturers do (that is part of my question concerning flycutting or not). If I were you, I would call Gunnar at Patriot and tell him what you want to do and he will point you in the right direction.
http://www.patriot-performance.com/w...05234&DID=1225
Old 03-05-2007, 04:28 PM
JakeY2KZ's Avatar
I run a very close cam to what you're going to use. Mods are in sig with the number I put down. No flycutting was required and driveability is great. I had an auto with the same mods and it still drove great. Just depends on how good your tuner is.
Old 03-05-2007, 05:14 PM
ICRAZY6's Avatar
Thanks guys, I'm getting this cam tomarrow. Now just need to decide on which heads to get. And if it worth it to upgrade the rocker arms to Harland Sharp?
Old 03-05-2007, 06:59 PM
cowboysfan's Avatar
great cam. I got mine from Comp Cam, here is set up. 231/237 .589/.595 112 +4 not sure what dif from TSP. PP LS6 S2 2.02in 1.57ex 59cc, stock size gasket. 418rwhp/389rwtq, m6, 3.42 . still running stock intake, tb, pully. no fly cutting, installed straight up. I'm sure with underdrive pully, roller rocker up grade, 90/90 setup can make 445/450 rwhp with good tuner.
fuerzaws6
Old 03-06-2007, 06:36 AM
93camaro_zzz's Avatar
I am running this combo of 231/237 114, and patriot stg II 5.3's. I bought the car with the H/C, and the owner told me that he milled the heads "As far as they could go, without the valves touching the pistons." I made 396hp/365tq with these mods:
MAC midlengths
TSp 3" OR Y-pipe
Magnaflow
Lid, SB, ported stock TB, LS6 intake
tune, LS7 clutch, 30#, 255lph
I plan to do a cutout and an UD pulley next, then look into LT's, FAST 90/90 and then some spray. The car was tuned for 50* weather in illinois, and then I moved to california where it is above 70* all the time. so I am also looking to get hp tuners. I will keep the forum updated on the results. I am hoping to get more power out of this combo, cause Im sure it can do more. Later, and good luck.
Old 03-06-2007, 07:23 AM
ICRAZY6's Avatar
Yeah I'm not realy sure what the difference between Comps 231/237 and TSP's 231/237 cam is except on the tsp's the lift is just a tad bit higher. The guy I'm getting the cam from ran it on a 98 ls1with AFR 205's with 59cc chambers and did 435rwhp and 410wrtq without some of the mods I'm adding to the setup. So I'm hoping for better than that. Is it any harder to tune for a 112 lsa than a 114 lsa? I know the 112 is going to sound meaner, any performance difference?
