LS1 engine, O2 sims, skip shift bypass
2000 Trans Am LS1 5.7 Engine SOLD, 87,773 miles
Runs fair, 17mpg in town, 29mpg highway
Includes;
Ls1 5.7 long block, 241 heads complete
ls1 intake manifold
oil pump
timing set
valve covers
rockers
harmonic balancer
cam
pushrods
lifters
(NO oil pan, pick up tube, or windage tray)
This was a great engine, but some one was a little hard on if before my girlfriend bought her car. Cylinder 5 is down on compression. Last time i checked it was 75-80psi and all the rest were 115-120psi. It uses a little more oil than than most ls1's. Closer to 1 quarts every 3,000 miles. It only needs a oil pan, pick up , and windage tray, as well as a small rebuild, Rings and bearings only, to be running like new again. Rod and main bearings are fine.
Again this is a running ls1,we pulled it out Tuesday night, she drove it into the garage. It was swapped out with a GTO 5.7 crate engine from SDPC, thats why there is no oil pan.
Girlfriends 2000 Trans Am m6
O2 sims $55.00 Shipped
Sims do have the red blinking light to show they are working
Skip Shift eliminator sensor kit SOLD
Includes sensor for harness , and fill sensor plug for the skip shift sensor on the trany
Includes;
ls1 intake manifold
oil pump
timing set
valve covers
rockers
harmonic balancer
cam
pushrods
lifters
