my 4l80/yank/supercooler/m6 conversion
Old 03-14-2007, 03:27 PM
MIGHTYMOUSE's Avatar
Default my 4l80/yank/supercooler/m6 conversion
im new to this section more or less so i thought i would show how my conversion turned out
Transformance 4L80e w/ rossler t-brake
http://fastrides.com/photos/mm/picture17224.aspx
the shifter
B&M Quicksilver
http://fastrides.com/photos/mm/picture16958.aspx
trans cooler
B&M 130-70274
http://fastrides.com/photos/mm/picture18814.aspx
the stall
yank 4l80 sc3000
http://fastrides.com/photos/mm/picture16957.aspx
flexplate
tci ls1, painted so i sanded it off on all contact points
http://fastrides.com/photos/mm/picture17900.aspx
also installed autometer temp gauge, have not installed the t-brake button yet
i bought a billet 4l80 slip yoke from strange, and swapped it to the end of my m6 denny's driveshaft. didnt have to change length etc.
i tied the park/neutral switch to the clutch switch wires, and tied the reverse light switch to the reverse light wires from the m6 harness, also tied in the output speed signal wire to get the speedometer back.
had to set the rear gear and tire size to really weird numbers like 6.0 gear and 19" tire but it is on the money now.
most all of my trans related pictures of the build are here:
http://fastrides.com/photos/mm/category1079.aspx
Old 03-14-2007, 08:07 PM
Z'mnypit's Avatar
Where did you get the speedo settings? Mine stays 2-5mph no matter what I do. Ive heard about using #'s like that but couldnt get any other info on it.
And I hope nothing hits your trans cooler, Ive never seen one mounted like that. Nice swap pics!
Thanks,
Vann
Old 03-15-2007, 06:55 AM
that was the only room i had, necessity is the mother of invention i got lots of other stuff lower than that heh.
i just changed the numbers in the direction the speedo was wrong until it wasn't wrong anymore
Old 03-15-2007, 12:05 PM
Z'mnypit's Avatar
Oh, Mines attached to the AC condensor in the front of the car. But I guess that would work.
Cool, Ill give that a shot.
Old 03-15-2007, 02:37 PM
i have an intercooler radiator and turbo pipes up there. it seems to be running cool so far down there, i have some aluminum to make an air dam for it if necessary
Old 06-06-2007, 09:04 PM
Mia
Mia's Avatar
what did you have to do to fit the shifter? did you shorten it, to fix the six speed ****?
Old 06-06-2007, 09:38 PM
i cut the handle off to fit a cut 6 speed handle shaft
the b&m is aluminum and the 6 speed handle is steel, so there was some funny business involved to mary the two.
Old 06-07-2007, 09:26 AM
Bryan @ Speed Inc.'s Avatar
that's hilarious man...
nice clean installs man... sweet conversion, sweet car.
Old 07-08-2007, 02:33 PM
02SSLE's Avatar
looks really good.
Old 02-02-2010, 09:17 PM
pics went bad, should be good again..
Old 02-03-2010, 11:18 AM
355TurboLT1's Avatar
All of your links go to cars.com lol
Old 02-03-2010, 03:52 PM
you are right, and i don't know why... researching...
Old 02-03-2010, 05:44 PM
try em now.
. also due to not having a fan on it, my trans temps were hot with that cooler under the car. RICE ETR on here has one under the car on the other side with a fan on it and it does ok.
but i let my intercooler radiador take over as my trans cooler, it has worked extremely well!
http://fastrides.com/photos/mm/picture16956.aspx
you can kinda see it here in front of the radiator on the passenger side
http://fastrides.com/photos/mm/picture19213.aspx
also i eventually replaced the steel line with the lightweight black hose, and i made this fitting for the trans
http://photos.streetfire.net/photo/0...pg_1721327.htm
http://photos.streetfire.net/photo/0...pg_1721328.htm
Old 02-27-2010, 11:51 AM
Gingervitis Addict
slow67's Avatar
try em now.
So the only thing wrong with it was the fluid was a little dark i'm guessing?
Old 02-27-2010, 01:12 PM
the fluid does that over time when racing anyways, but yea cooler is better.
the temps would keep climbing before and i didnt have a way to cool it down, now i can manage the trans temp pretty fine, and now with the fan i can cool it off even when i am sitting still.
Old 02-27-2010, 02:10 PM
Gingervitis Addict
slow67's Avatar
Do you know what sprag/drum setup you have?
Old 02-27-2010, 09:53 PM
lmt0705's Avatar
what are you using for a crossmember
Old 11-29-2010, 08:19 PM
grifter757's Avatar
How did you wire the car up? Did i miss that.
Old 12-01-2010, 04:51 PM
sorry i got unhooked from this thread somehow
jim at transformance can detail you on the trans build
i have a bmr trans bracket
the 80 is controlled / wired to bs3 plug and play
Old 12-01-2010, 11:57 PM
69TA's Avatar
Mightmouse,
Do you know if you can piggy back the BS3
so that you can keep everything else operating
for lets say a street car
Quick Reply: my 4l80/yank/supercooler/m6 conversion
