Anyone Interested In 14" Brake Kit?
First of all, this is for LS1 cars only and you need to have at least 18" rims. This also isn't intended for race track use, but for street cars.
What I'm trying to do is mount the C6 Z06 rotor which is 14" to the front of the LS1 car and then reuse the stock caliper, PAB and brake pads.
The rotors are only about $90ea, easy to get should just slip right on with no mods.
The hard part is making a adapter to space out the stock PAB one inch and get everything lined up. Then make everything super strong so it will last forever under extreme conditions. This is the hard part I'm undertaking.
Would anyone else be interested in these brackets?
EDIT The: stock calipers won't fit over a rotor that large. It's much easier to bolt the Cadillac CTS-V 4 piston calipers right onto the LS1 spindles. They cost roughly $160 each including pads.
Originally Posted by lo_jack
Don't you have enough projects already Jason?
I can't control it. I just get ideas. I'm getting some new rims, probably 19's, so I got thinking about some bigger rotors and stronger brakes. If I can do the whole front for like $400-$500 bucks it would be great. After lots of tests and so forth it may be worth while to produce a batch and sell them, but I'm a long ways from that point.
I have the c5 brackets and rotors already but I would definately be interested to see how this goes.
I'm just floating this idea out there to see what kind of interest there is.
FYI there is a company that already does this and their brackets are $105 for the pair. If you can possibly beat that, then I'd say go for it. Otherwise, you might want to take on another project. Not trying to rain on the parade or anything, but its already been done.
Excellent! Excellent! Please tell me more. PM me if you can't post it.
I didn't really want to have to reinvent the wheel anyway.
I think I found the ones you mean. From Kore3, right?
I was looking over things and I really don't like their design. It seems prone to twisting.
It also isn't $115, that's just for the brackets, you'll also have to buy new C5 PABs which run about $50 each. So their kit is actually about $215.
The worst part is they say you have to modify the spindle. I think they want you to cut that lower PAB mount on the spindle just like you do with the 13" kits. That sucks. You shouldn't have to do that. In fact they should have used that lower mount to bolt to the bracket. That would help prevent twisting.
No, they are slightly different. Either caliper should slip into it, though.
If only I could find a 14.5" rotor on the cheap. Then I could use the Z51 bracket. Booya!
I'm afraid I'm going to have to open this back up. I probably won't sell anything, but I'll post up info.
After talking to the guys at Kore3 I've decided that I don't really want to use their setup. I really would be better off using a caliper that was made for a larger diameter rotor, so instead of buying the C5 stuff, I think I'll adapt the 4 piston Brembo's from the CTS-V. I can get the complete caliper with pads and clips for $166 each. All I would need to do is make a bracket to attach them. This seems the much better option in my case.
Now THAT is something I'd definitely be interested in. Once the pads on my current C5 kit setup wear out, I'm wanting to go with something bigger or at least better and i'm leaning towards the 14" kit Kore3 offers unless I can find something like what you are talking about doing. Excellent idea!
All the guys at Kore3 have to do is make a new bracket spaced to mount the 4 piston caliper. It's very similar to the F and Y body PAB mounts. See below.
I'm going to ask them about it. Maybe they can do a handfull of these brackets for me and a few others.
You'll need spoke clearance if you want to run the Z06 rotor, though.
Hey Jason -yeah I hacked my spindles. But they are easy enough to come by. For the time being my $16 rotors please me.
Those CTS-V calipers are wild. You need someone to waterjet you brackets, is that where this is heading? Or do you still have a rotor source problem as well? I have a place I like for OEM rotors...PM me.
I see 2 options mainly.
1. I can cut both spindle mounts off and get a partially cut plate from Kore3 that will bolt to the hub, but let's me choose the caliper mounting location.
2. Depending on how close these calipers are to fitting with the stock mounts, I may just weld up the holes and redrill them or mod them in some way that retains their strength while allowing the calipers to just bolt on.
More info here:
https://ls1tech.com/forums/showthrea...6&page=1&pp=20
More info here:
Another interesting option is using a C5 bracket kit, but use the 6 piston Z06 calipers as they will bolt on along with the 14" rotor. That's an easier installation, but the calipers cost about $260 each and I don't know if pads are included or not in that price.
I'm actually considering this as well, but I hate that the pads cost so much. Front needs 12 little pads at about $30 each. It adds up.
It's actually a fairly common caliper made by Brembo and used on ferrari's, lotus's, the viper, evo's, etc... Brembo just changes the mounting lugs and the name/color of it. There are a huge number of pads for it as well. The Porche TT calipers are still probably the best for the hardcore racer, but cost around $1300 pr. These Brembo's are much cheaper and work just as well for street and light track use.
The CTS-V are so attractive due to their price. $166 loaded with pads is very cheap.
I would definitly be interested in some sort of bracket if you chose to do that versus the c6 z06 calipers..
After new rims and tires and stuff I may have to do the brake thing on the cheap. My moneys running low.
I'm wondering how much of a difference there is in caliper dimensions as far as the rotor diameter is concerned as opposed to the PAB dimensions? If I use the Kore3 bracket, bought the C5 PABs and mounted them with the 14" Z06 rotor I wonder if the LS1 calipers and pads would fit over it?
If I'm not mistaken the LS1 pads can be modded slightly to fit the C5 PABs as I remember people doing it before. I have these grippy pads that seem to last forever, but they eat rotors for breakfast, lunch and dinner.
I would sure like to keep using them to save myself $200 for the front pads.
I do have plenty of clearance for the 4 piston caddy calipers, though:
Something like this would be so awesome, though.
So it's $415 to keep using the stock calipers or $655 plus new brake lines ($?) for the 4 piston setup. So a $240 (plus brake lines) difference, plus some modding of the Kore3 bracket. Or I could just get the caddy calipers and do my own engineering to mount them which would bring the total to $540 which is a $125 difference in cost over using the stock calipers.
Do you guys think the 4 piston fronts are worth the extra money?
I would sure like to keep using them to save myself $200 for the front pads. I do have plenty of clearance for the 4 piston caddy calipers, though:
