Nitrous Wiring
Old Mar 19, 2007 | 05:49 PM
Lythropus's Avatar
Default Nitrous Wiring
I just need some advice on my system wiring. This is my plan:
First Stage: 3200-6500rpm
Second Stage: 3600-6500rpm with first gear lockout
Shifting at 6650-6800 (Don't know until the dyno results...) or so with shift light set-up 50rpm before shift, rev limiter at 7000 just to be safe...
Here is the diagram...
The only difference from the diagram is that I might put the FPSS's on the ground coming off of the window switch...
Thank you mrr23 for the diagram I modified to fit my needs...
When at the track I can arm it and use it normally, but let's say I only want to use the second stage I should be able to hit the master arm switch (while leaving first and second stage switches off) and rev it to the limiter. This way the window switch should think it's been through first gear, I should then just be able to select my first stage, second stage, or both to activate in first gear. The same thing being true if I were on the highway and wanted both stages, I should be able to hit the master arm, rev it to the limiter, and turn on both stages so they both hit without one waiting for the next gear...
I would like to not have to change any settings on the window switch at the track or on the street since the car will see a fair amount of both...
Any input would be greatly appreciated, I just want to make sure I can get it right the first time.
-James
Old Mar 19, 2007 | 06:42 PM
Lythropus's Avatar
bump bump
Old Mar 20, 2007 | 08:20 PM
Lythropus's Avatar
yooohooo...
Old Mar 21, 2007 | 06:42 PM
Lythropus's Avatar
42 views, 2 days, please...
Old Mar 21, 2007 | 06:44 PM
brad8266's Avatar
Look ok to me
Old Mar 30, 2007 | 09:09 PM
Lythropus's Avatar
bump for an old thread I'd like some more comments on...
Old Mar 30, 2007 | 09:17 PM
Todd157k's Avatar
Originally Posted by brad8266
Look ok to me
+1
Old Apr 1, 2007 | 11:54 AM
Beer99C5's Avatar
-James
I don't know...seems to be missing something....
Oh ya, dere it is
Old Apr 1, 2007 | 12:50 PM
Lythropus's Avatar
for real now...
Old Apr 2, 2007 | 10:24 AM
GT Griller's Avatar
Oh ya, dere it is
