05-07 Mustang GT ZEX Wet Kit, F-Body Stuff: Bezels Switches Trim, other stuff. 56K no
Old Mar 19, 2007 | 09:32 PM
silvachris1's Avatar
Arrow 05-07 Mustang GT ZEX Wet Kit, F-Body Stuff: Bezels Switches Trim, other stuff. 56K no
Long Story Short, found some cars at a junkyard. Here's what I got. Make me some offers.
93-96ish Firebird Stuff
Driver Side Door Handle Bezel: $5.00+ shipping SOLD!
Driver Side Window/Lock/Mirror Switch Plate $5.00+ shipping SOLD!
Driver Side Window Switch $7.50+ shipping SOLD!
Driver Side Lock Switch $5.00+ shipping SOLD!
Radio/HVAC Bezel $20.00+ shipping SOLD!
Driver Side Mirror Switch is Broken, but I have the button parts $2.50+ shipping
Passenger Side Door Handle Bezel $5.00+ shipping
Passenger Side Window/Lock Switch Plate $5.00+ shipping
Passenger Side Window Switch $5.00+ shipping Tested and works
Passenger Side Lock Switch $2.50+ shipping (superglued together) Tested and works
Tweeter Cover $2.50+ shipping ?Appears to fit all years?
Gauge Bezel w/ Vent $20.00+ shipping ?Appears to fit all years?
93-96ish Camaro Stuff
Passenger Side Tail Light $40+ shipping SOLD!
Berger Panel $100.00+ shipping SOLD!
Passenger Side Window/Lock Switch Plate $5.00+ shipping SOLD!
Passenger Side Window Switch $2.50+ shipping (superglued together)
Passenger Side Lock Switch $5.00+ shipping Tested and works.
Passenger Side Door Handle Bezel $5.00+ shipping Appears to fit all years?
Taillight Harness (Complete, but not shown complete in pics) $20.00+ shipping
Fog Light Switch $5.00+ shipping Has not been tested
93-96 Interchangable Stuff:
Knee Panel Under Steering Column $20.00+ shipping SOLD!
1 Driver Side Triangle Mirror Plate $5.00+ shipping SOLD!
Fuse Panel Cover $5.00+ shipping SOLD!
Trunk Release Button $5.00+ shipping SOLD!
2 Passenger Side Triangle Mirror Plate $5.00+ shipping each SOLD One 1 left.
2 Trunk Release Actuator Assemblies $15.00+ shipping each SOLD One 1 left.
Door Lock Slider Thing $1.00+ shipping
2 Console/Door Handle Bezel Light Harnesses $2.50+ shipping each
Driver side Door/Window Rubber Seal (goes at the the back end of the door near the window) $1.00+ shipping
Locking Lug Nut Removal Tool $5.00+ shipping
Rear Hatch Weather Stripping (2 small cracks in it) $15.00+ shipping
All previously mentioned parts are sold AS IS and O.B.O. + shipping, if you think the price is too high, make me an offer, pick up multiple parts and I'll cut you a deal, and save you some cash on shipping. Lastly, I reserve the right to sell some parts to local people without notice. Parts are sold on a first come first serve basis.
1998-2002 Camaro Billet Grille. $30+ shipping SOLD!
GM 3.42 Gear Set. $50 bucks+ shipping?. Gear is from a 99 or 2000 Z28. I dunno if that makes and difference to you guys.
Stock axles $50+ shipping each or $80 +shipping for both. Shipping should be $24 each or $30 for both. One of them has around 1500 miles on it.
1 Stock 10 Bolt Differential Cover $5+ shipping.
Stock rear sway bar (15mm?) from a 1999 V6 car. $15+ shipping.
1LE 21mm Rear Sway Bar w/ bushings and endlinks. $65+ shipping. I paid over 120 for it last year from GMPartsDirect.com. They don't appear to have them anymore either.
Stock 2001 WS6 Panhard Bar. $15+ shipping. Good condition, little surface rust, nothing you wont find on the stocker under the car.
Stock tan floor mats, front and rear. $20+ shipping SOLD! If you buy, I'll clean them up before I send them.
Stock Monsoon Amp. $5+ shipping SOLD!.
PRICES REDUCED
ZEX Wet Kit $325+ shipping
I really never got around to using the nitrous much since it got cold too soon after I got it. I made 4 passes with it, but the bottle pressure was about 600psi, so I really never found out what it was capable of. It’s a ZEX Wet Kit that I got if from a buddy of mine when he traded in his '05 Mustang GT. Here's a link to the kit on their site: http://www.zex.com/Products/NitrousO...&Store_Code=ZX. I've got everything you need to hook it up in an V6 F-Body, or to put it back in a GT. That page talks about special parts for the Mustang fuel system. It's just a CNC machined fitting, with a rubber o-ring, that bolts to the Mustang fuel rail. For the F-Body, I just hooked right up to the Schrader valve on the fuel rail.
Included in the kit:
1 Nitrous Management Unit
2 24" steel braided hose, -3AN
1 3' steel braided hose, -4AN
1 18' steel braided hose, -4AN
1 Nitrous Nozzle
1 1/8 NPT Bulkhead Fitting w/ nut
1 Ford Fuel Rail Adaptor
1 Spare Fuel Adaptor O-ring
1 -4AN to 1/8 NPT Fitting
1 10lb Nitrous bottle w/Valve (has scratches on the back from the brackets)
1 Bottle mount bracket (short)
1 Bottle mount bracket (long)
1 .026 N2O/Fuel Jet
1 .030 N2O/Fuel Jet
1 .034 N2O/Fuel Jet
1 .038 N2O/Fuel Jet
1 .040 N2O/Fuel Jet
1 .043 N2O/Fuel Jet
1 .046 N2O/Fuel Jet
1 .054 N2O/Fuel Jet
1 .067 N2O/Fuel Jet
1 .083 N2O/Fuel Jet
1 Power Point Arming Switch
1 Wire Harness w/ Lighted Red Toggle Arming Switch
1 Red Power wire (unsure of length, enough to go from driver's seat to engine bay)
4 5/16-18 X 1" Bolt for bottle Brackets
4 5/16-18 Nut for Bottle Brackets
4 5/16 Flat Washer
2 M5 x 40mm Hex Head Bolt (Unsure if I have this, there are extra bolts, but I don’t know the size)
2 M5 Washer (Don’t have these, I’m including 2 extra that fit the extra bolts)
4 Sheet Metal Screw (Holding the NMU to the Brackets)
2 20A 32V Fuse
1 10A 250V Fuse
1 0.2A 250V Fuse
Extra stuff for the nitrous that isn't in the kit:
20 Zip Ties
1 Bottle Mount for the hatch
2 Custom NMU Mounting Brackets
2 Self Tapping Bolts (Mounts NMU to passenger side inner fender, next to battery)
1 ZEX Nitrous Pressure Gage (Leaked off pressure, I tightened it, but didn't use it afterward)
1 Printed ZEX Nitrous Installation Instructions for the Mustang GT
Not Included:
1 -4AN 90 deg. Swivel Fitting (supposed to be in the kit, but I do not have it)
Having the bottle mount and the NMU brackets already made will save you some hassle. The bottle mount prolly isn't going to add a whole lot extra to the shipping cost. It's about 1.25" thick, and fits perfectly down inside the hatch hole. If the buyer decides they don't want it to save on shipping, that's fine. The NMU brackets are made to bolt up onto the passenger side wheel well using 2 existing holes in the cars sheet metal. I’ll also consider trades, just ask.
I will consider some trades, just make an offer and I'll let ya know.
Scratches on the bottle:
PowerTuner (PCM not shown)
DHP PowerTuner with A/D wideband support. $300+ shipping For 99 3.8 V6 Camaro, and 2005 Pontiac GTP. I'll also include a PCM that's already programmed (used the VINchanger to match the VIN on the PCM to mine) for the 3.8 Camaro, a 100+ page printed and bound operations/instructions manual. Extra: Serial-> USB cable. This convertor has worked flawlessly for me each time I've used it. I've never had a communication error because of it, and I've tuned the PCM with no problems. This thing is supposed to tune any 97-05 GM 3.8V6 too.
Open to some offers.
Ring gear (on a dead Zexel Torsen):
Pics of the pinion gear available upon request.
Stock rear sway bar (15mm?) from a 1999 V6:
Stock GM Axle Shafts. One used, one with around 1500 miles:
Stock WS6 panhard rod:
Tan Floor mats:
93-96 Camaro Taillight Harnes:
Firebird Door Handle Bezels
The pictures don't show it, but there is a tiny bit of discoloration on them.
Knee Panel and 93-96 Firebird Guage Bezel (maybe usable on later years, I wouldn't know).
Knee panel has the normal rub marks where it meets the gauge bezel and the typical scratch marks found on them. Both parts have some discoloration.
Window Switch Plates for 93-96 Firebird and Camaro (prolly usable on later years), 93-96 Firebird Radio Bezel, Window/Mirror Triangles, Fuse Panel Cover, Locking Lug Nut Key, Tweeter Cover, Misc. Window/Lock Switches, Door Handle Bezel Light Harnesses:
93-96 (and maybe later?) Firebird Mirror Control buttons (not the actual switch), Sail Panel Speaker Covers, Trunk Acuators/Latch Mechanisms
Back Hatch Weatherstripping
Damage to weatherstripping
All the parts listed from the 93-96 Camaro and Firebird are from a Junk Yard, they've been exposed to the weather and who knows how many idiots. They will not be in perfect condition. I will consider some trades, just make an offer and I'll let ya know.
Old Mar 20, 2007 | 05:32 PM
Any interest?
Old Mar 21, 2007 | 05:06 PM
Hugger's Avatar
I just sent you a PM, but I just realized you don't have the driver's side window switch bezel for a camaro. Let me know if you have one.
Old Mar 22, 2007 | 02:30 PM
PM sent, no driver's side. I'll see what I can do.
Old Mar 31, 2007 | 12:22 AM
Bump it up. I tested the window switches, they work.
Old Apr 2, 2007 | 03:49 PM
midwest_98's Avatar
how much for the berger panel shipped to 63129? extremely intrested
Old Apr 2, 2007 | 05:42 PM
onebadbird96's Avatar
Driver Side Window Switch $7.50 Tested and works
Driver Side Lock Switch $5.00 Tested and works
Passenger Side Window Switch $5.00 Tested and works
Passenger Side Lock Switch $2.50 (superglued together) Tested and works
pm me with a good price on all this stuff shipped to 30122 ga
Old Apr 2, 2007 | 08:37 PM
PM Sent. $25 shipped?
Old Apr 2, 2007 | 08:59 PM
PM Sent.
Old Apr 2, 2007 | 09:57 PM
i ment to ask you when i pmed you back do you have the window motors ?
Old Apr 2, 2007 | 10:44 PM
PM sent, I don't have the window motor, but might be able to get ONE from the car. Drilling the rivets out of the the regulator is not fun when you're at a Junk Yard. I'll set both 18V batteries to charge. Lol.
Old Apr 8, 2007 | 10:06 PM
:crickets:
Old Apr 8, 2007 | 10:10 PM
TX aggie TX's Avatar
Will the 3.42 gears work on a 03 chevy 1500 pickup? If so Ill do 50$ shipped?
How many miles...condition good?
Old Apr 9, 2007 | 01:58 AM
I'm really not sure if they'll work in your truck or not. Knowing GM, there's a pretty good chance that they might. I know that the gears are from a 7.5"-7.625" GM 10 Bolt Rear, out of a 01 T/A WS.6. The gears are in good shape, mileage was around 50K I think when the rear was pulled from the car. I didn't see anything unusual about them..... cracks or wear. The gear oil was pretty clean when it came out, and I don't recall seeing much (if any) metal shavings in the oil. However, I cannot be 100% sure of the abuse they've seen. I was askin $50+ shipping, but if the the weight doesn't make it too expensive, I can do that. I'll have to check the weight and the box size to be sure. PM me, and I'll send ya something back later on the price.
Old Apr 13, 2007 | 01:59 AM
Havok2's Avatar
berger panel sold. payment sent. thanks.
Old Apr 17, 2007 | 02:58 PM
Berger Panel shipped after fighting with the Post Office for 2 days.
Old Apr 19, 2007 | 07:16 PM
vjo90rs8's Avatar
Default 21mm rear sway bar bushings
If they are still available, would you be willing to separate the 21mm poly rear sway bar bushings.
thanks,
david
Old May 7, 2007 | 11:38 PM
thanks,
david
To my knowledge, the bushings are not poly. I'd reall prefer not to seperate, but if you really need a set, make me an offer, they arent doing me any good sitting there.
Old May 29, 2007 | 07:02 PM
SSinNC's Avatar
I'll give $5 shipped for the locking lug nut removel kit.
