Vortech aftercooler kit
Complete Vortech aftercooler system for the Vortech superchargers for LS1/6 motors. This kit allows you to run 9 to 10 punds of boost safely. When I bought this it was originally the as cast version, no finish. I polished the entire system before bead blasting the system. It is bead blasted to a very fine satin sheen and then clear coated. It looks awesome, especially in the sun. The aluminum parts are absolutely smooth, no bumps at all. If you wanted to polishe this again, it would be very easy to do.
The only thing missing are two of the rubber pipe couplers. These are cheap and easy to buy though. The cooler, the piping and the coolant fill tank are all finished and clearcoated. For the whole sytem, all fittings are installed correctly where they go and are water tight. There are pictures below, they should give you a good idea of the finish.
Included is all you see in the pictures .There is a little groove on part of the aftercooler where my hood rubbbed on it. You won't really notice it very much.
$1000 takes it all. It sells for considerably more from vortech. The cooler itself costs $1500 or so from Vortech. PM me or email with any questions to jcooper1320@comcast.net
Sorry about the giant pics!
