No code, but "TCS OFF" light won't go out
Old 03-24-2007, 05:39 AM
Quickin's Avatar
Default No code, but "TCS OFF" light won't go out
What causes the "TCS OFF" light in the gauge cluster to stay on all the time?
And the orange light on the TCS switch is out.
Is there a fuse somewhere for it?
Old 03-24-2007, 10:46 AM
Jeff 97 Formula's Avatar
What happens when you push the switch?
Old 03-24-2007, 06:52 PM
Quickin's Avatar
Nothing at all, its just dead. But the gauge light stays on always, from start to shutdown.
Old 03-25-2007, 07:21 PM
96blkformula's Avatar
there is a fuse for that but when i took mine out it always has the light on thats just my $.02
Old 03-25-2007, 07:28 PM
Quickin's Avatar
Where's the fuse for it?
Old 03-25-2007, 09:20 PM
CW00BlackTA's Avatar
In the fuse box under the hood--on the drivers side in front of the wheel well.
Old 03-25-2007, 10:14 PM
Jasonscott's Avatar
Not trying to hijack, but I just got done with a cam install and my tcs off light is going on and off by itself, I wonder if we have the same issue?
Old 03-25-2007, 10:16 PM
Quickin's Avatar
Thanks, I'll check. If the fuse pops will that make the light stay on in my guage cluster?
Old 03-26-2007, 03:08 AM
CaliboyTA's Avatar
I'm having the same exact issue u having.
Old 03-26-2007, 05:30 AM
LS1Tech Sponsor
Slowhawk's Avatar
Alot of times it's a loose wire near the rearend.
Old 03-26-2007, 06:41 AM
98WsSick's Avatar
i had the same problem it was the fuse.
Old 03-26-2007, 07:27 AM
magius231's Avatar
if the computer is detecting misfires (like with a new untuned cam) it will cause this...I get the same effect if I try to hit the button while idling with my new cam just installed. Check for misfire codes/etc.
Old 03-26-2007, 11:56 PM
Yes. The light stays on in the guage cluster any time the TCS is off or if the fuse is pulled or blown. I've never figured how to make it go out except to turn TCS on.
Old 03-27-2007, 12:41 AM
PICNIC_GEORGE's Avatar
My TCS OFF light is always on and I know its not the fuse. When you pull the fuse the light won't turn on until the car starts moving. My TCS and Cruise control do not work but my ABS does... So I'm not sure what the problem is. Everything looks good but my TCS switch has been tampered with. Still doesn't explain why I have no cruise control hmmmm.
Old 03-27-2007, 06:37 AM
Senior Member
Country Boy's Avatar
make sure the TCS is plugged in. Theres a small connector thats right by it.
Old 03-27-2007, 11:26 AM
wait4me's Avatar
Do you have the original computer program or Bcm in the vehicle? It may just be shut off in the calibration. The bin files contain that information as does the BCM/ ABS module.
Old 03-27-2007, 09:09 PM
Quickin's Avatar
I'm sure this is just a little gremlin in my situation, but I thought I'd tell ya all what I did today.
I simply removed my TCS fuse, it was just fine so I put it back in. Started it up and the light was out on the guage cluster and the TCS light was illuminated normally. Drove around all day today and the TCS OFF light is out and the TCS works perfectly. I turned it on and off a bunch of times and its back to normal.
Who knows.
Old 03-27-2007, 11:31 PM
Who knows.
That's pretty sweet.
Old 03-28-2007, 09:13 PM
senicalj4579's Avatar
i'm having the traction control problem and code P0121 after my ls6 intake install. the engine surges off and on. traction control off light will not go off
Old 03-29-2007, 02:50 AM
Quickin's Avatar
P0121 = Throttle Position Sensor
Quick Reply: No code, but "TCS OFF" light won't go out
