Huge Ls1 & Lt1 Parts & Car Sale!!!! Look Inside!!
Old Apr 4, 2007 | 05:23 PM
BoostJunkie's Avatar
Restricted User
Arrow Huge Ls1 & Lt1 Parts & Car Sale!!!! Look Inside!!
2002 LQ9 4x4 drivetrain 345hp 22k miles only needs PS pump & Xfer case for drop in conversion. $3000
2004 LQ9 4x4 drivetrain 345hp 2k miles only needs starter. $3500
402 CI short block LS2 block, Eagle cranks & rods, diamond pistons $4000
402 CI short block LS2 block, Eagle crank, Lunati rods, diamond pistons $4200
NOS LS1 Nozzle nitrous kit P/N 08301NOS
Kit has only had 4-5 bottles through it.
Comes with NOS standard jetting, I think 125hp.
$1100 Shipped Also have 300hp jets if you want for $170 additional. SOLD!
LS2 intake new takeoff with rails injectors & TB SOLD!
LS2/LS7 90mm electronic TB new takeoff $200 shipped SOLD!
FAST 90mm intake new in box $710 shipped SOLD!
Patriot Gold springs new in box $240 shipped
Patriot Xtreme springs new in box $275 shipped
Comp Cams 921 spring set used 300 miles $350
Comp Cams 921 spring set removed from new heads never run $475
Comp Cams 918 springs new in box w used Titanium retainers $250
LS1 Valve cover spacers new in box $130
60lb injectors new in box flow matched $400
42lb injectors new in box Lucas flow matched $325
LS7 clutch slightly used complete w/ flywheel excellent condition SOLD!
Accell Gen 7 LT1/LT4 EFI New in box Gen 7 System.
No wide band, Innovate Wide Band can be used instead of Accell's $450 wide band option. First $1300 takes it!
LT1 blower engine 355ci nodular crank, eagle rods, forged pistons, AFR LT1 heads by GTP, comp rockers, ARP studs, FAST bank to bank ECM, Injectors, Intake converted for MSD Dual Sync distributor, Distributor, Fuel rails converted for AN fittings, etc. $6500
93 Trans AM hard top Auto Red w cloth interior, 68k miles summer driven only, 6pt cage, 9" ford w spool & wilwood brakes, Dual Fuel System includes 2 external Walbro 255 pumps for engine w AN lines and 1 Walbro 255 external for NOS system w AN lines, $6000 rolling chassis
99 Trans AM WS6 M6 T-Tops silver w black interior, VFN ram-air hood, great condition, Georgia car very clean $4900 rolling chassis
93+ Trans Am Drivers Door w glass Red $200
2006 Ford V10 3 valve complete takeout engine w ECM & harness 250 miles $2200SOLD!
NEW ADDITIONS:
LG Motorsports G5X3 cam on a 114 LSA used only 300 miles $325 SOLD! SOLD!
Strange 12 bolt 35 spline axels 3.73 gear TA cover posi used only 1K miles $1750 for axle or $2000 with New Moly driveshaft
04 GTO LS1 350hp long block only 1,500 miles $2000
T56 from my 99 SS F-body good workning trans no issues $1200
SPEC stage 3+ with billet flyweel used for 2k miles $500 SOLD!
SPEC Stage 3+ New In box $530 w Steel Flywheel $238
Lingenfelter LS6 CNC ported heads for 4.125 bore, Inconel Ex valves.
From a Twin Turbo 725hp 427 Vette 5k miles perfect condition. $1800 SOLD!
LS2 33lb injectors new set of 8 $175
McLeod Street Twin LS1 clutch 5k of street use $850 SOLD!
Old Apr 5, 2007 | 11:31 AM
Restricted User
Bump!
Old Apr 7, 2007 | 07:15 AM
SEDUCE's Avatar
550for manifold?
pm me if ok
Old Apr 7, 2007 | 09:18 AM
Restricted User
Sorry seduce I did not file bankrupcy.
Keep looking.
Old Apr 7, 2007 | 09:30 AM
JRracing's Avatar
What brand injectors are they?
Old Apr 7, 2007 | 11:04 AM
NeedATA's Avatar
Can I get pic's To gen3camaro88@aol.com Thanks Terry
Old Apr 7, 2007 | 05:27 PM
SEDUCE's Avatar
Ok When U Say 710 Shipped Is That To Australia?
Old Apr 7, 2007 | 06:58 PM
XxNaSDaQxX's Avatar
Pm Sent.
-J
Old Apr 8, 2007 | 12:20 AM
linegtdt52's Avatar
Default car
I would like some more info on that ga trans am
Old Apr 8, 2007 | 02:26 AM
TARZAN's Avatar
PM Sent
-Will
Old Apr 8, 2007 | 02:46 AM
Jeff@TotalPerformanceEng's Avatar
Do the 921's come with everything?? Or are they springs only?
Old Apr 8, 2007 | 10:26 AM
Restricted User
JR wich injectors?
NeedaTA I will get some pics Monday.
Seduce the lower 48 only.
linegtdt52 what do you want to know? PM me.
AmericanHP the 921s include everything.
Old Apr 8, 2007 | 11:18 AM
willyss01's Avatar
Default clutch
does the ls7 clutch *** with the ls2 flywheel for the ls1 cars. And how many miles does it have on it. have any pics. Send to willyss01@hotmail.com
Old Apr 8, 2007 | 04:26 PM
SEDUCE's Avatar
JR wich injectors?
whats the lower 48 only mean mate??
Old Apr 8, 2007 | 05:08 PM
Restricted User
Clutch includes flywheel. Only has a couple thousand miles on it. I can get pics tomorrow.
Lower 48 of the United States of America, does not include anyting below the equator, Sorry.
Old Apr 8, 2007 | 05:36 PM
Cheatin' Chad's Avatar
If you could post or send pics of the 99 I would appreciate it.
cheatinchad@hotmail.com
Old Apr 8, 2007 | 06:46 PM
2000 Ultra Z's Avatar
what brand injectors are the 42 and 60 and are they brand new or used
Old Apr 8, 2007 | 07:22 PM
Restricted User
Like it says:
60lb injectors new in box $380
42lb injectors new in box $325
60s are Siemens Deka from Precision Turbo flow matched
42s are Lucas from Precision Turbo flow matched
Old Apr 8, 2007 | 07:29 PM
Restricted User
Chad, you can drive over here and look at it in person if you like I am in Stillman Valley.
Old Apr 9, 2007 | 01:12 PM
Great, I'll PM you contact info.
