A/C delete guys
Old Apr 17, 2007 | 11:10 AM
CNTLSE 1's Avatar
Default A/C delete guys
I'm in the process of removing my A/C now and I have two questions. What did you use to block off where the two lines went into the firewall and what size is the torx holding on the dryer bracket? Thanks
Old Apr 17, 2007 | 11:54 AM
RICEETER's Avatar
i asked the same thing about the lines when i took mine off but no one here could answer. i just so happen to know some who know some people who had me one custom made. just a little plastic block about an inch thick with the two holes for the bolts and two counterbored holes for the lines. good luck with that.
and i dont remember the size of the torx bit. sorry
Old Apr 17, 2007 | 11:56 AM
CNTLSE 1's Avatar
So how about you have me one made? If I could get the measurements I could make one out of metal at work and have it powdercoated to look nice. Thanx for the help though
Old Apr 17, 2007 | 01:14 PM
RICEETER's Avatar
this stuff is like a hard plastic/composite material. i wonder how it would powdercoat
Old Apr 17, 2007 | 01:15 PM
CNTLSE 1's Avatar
my powdercoater said he baked it at 400 degress so throw one in the oven and see what happens.
Old Apr 17, 2007 | 01:19 PM
RICEETER's Avatar
hmm, might melt
Old Apr 17, 2007 | 01:22 PM
CNTLSE 1's Avatar
might not too
Old Apr 17, 2007 | 03:28 PM
8a8mfh's Avatar
Why are you deleting half the a/c stuff? Why not take it all out from under the dash.
To some people a/c is dead weight even if it works, but you're taking out half making it not work at all and taking out only half the weight.
Old May 1, 2007 | 03:15 AM
bowtiguy's Avatar
I'll buy your used low milage take-off A/C pump and front lines from the dryer to the pump. Just let me know.
-=MIke
Old May 1, 2007 | 03:21 AM
ModernMusclecar's Avatar
the torx is either a T30 or T35 can't remember which
