RotorsOnline House Disc /or Brembo Disc Package 97-04 C5/Z06 Corvette
This brake package is for the 1997-2004 C5 & Z06; I put this package together for a street car that sees mild to medium track use. There are two variation of the package listed below.
1st - House package
- 4 (front & rear) of our house discs.
- Front & Rear Hawk HPS brake pads.
- Techna-fit braided stainless steel brake lines. (4-Line kit)
- Front & Rear NHT powder-coated brake calipers.
- $925.00 shipped anywhere in the 48 States & Canada.
2nd - Brembo Package
- Everything the same as above except;
- House discs are replaced with Brembo discs. Blank & NIB.
- $985.00 shipped if you would like for me to machine and zinc the Brembo discs.
No modifications needed. Direct replacement.
The majority of this package is manufactured in North America. Given the exception to my house discs. (Made in Asia).
Techna-fit brake lines are manufactured and assembled in Torrance, CA. The COR-1200 braided stainless-steel line kit can handle up to 3500+psi and is built to MVS-1006 specifications.
NHT calipers are assembled by QB Rebuilders in Stockton, CA. QBR maintains ISO 9001:2000 quality standards. Designed to meet & exceed original manufacture standards/specifications. More info can be found here (http://www.nugeon.com/products.aspx?i=cc)
NHT calipers are powder-coated to order and are available in Red, Black, Silver, and Yellow.
***Important Note*** NHT calipers come with a core redemption coupon (mail-in rebate). With this packaged it is valued to $200.00. Each NHT box comes with the coupon & directions on how to redeem your coupon; simply send NHT your undamaged calipers.
Time to process and ship is up to 7 business days.
***Note I will soon be posting a package similar for the C4 & C6.***
1st - House package
Originally Posted by GhoSStrider
Do you have a similar package for f-bodies or will this setup fit?
https://ls1tech.com/forums/sponsor-sales-specials/646252-rotorsonline-house-disc-brembo-disc-package-93-02-f-body.html
It is $40.00 for the set of four discs.
It can be done in silver or black zinc.
Originally Posted by BobZo6
What would you charge for blank zinc coated Brembo discs for a ZO6?
