FS: Low mile LS1 longblock $1600 pickup
I've got an LS1 longblock for sale.... It is very low miles (~10-15k)
This is exactly what it comes with:
LS1 block (complete)
LS1 853 heads with new LS2 springs (I had these laying around and was going to just pitch em anyway. They're better than the LS1 springs)
GM MLS head gaskets
Oil pump
Timing set
Oil pump pick up
Windage tray
Fbod oil pan w/level sensor and gasket
Front cover w/gasket
Rear cover w/gasket
Valley cover w/gasket
Cam position sensor
Crank position sensor
Oil pressure sensor
Knock sensor harness
Fbod crank pulley
LS1 rockers/stands/pushrods
LS1 lifters and trays
01 Fbod camshaft
Valve covers w/ new gaskets powder coated gloss black
LS1 water pump
Under manifold coolant crossovers
Non-EGR LS1 intake
MAP sensor
Fuel rails
28.8lb injectors
78mm Cable thottle body
TPS sensor
IAC sensor
SDPC LSx engine dolley with casters
All this is assembled of course.
I could also include a SPEC 2/3 clutch that has about 1200mi. on it for $200 extra. (SPEC 2 disc and SPEC 3 pressure plate)
NOW bottom dollar...$1600 pickup only for this week! Then it's going to ebay SOLD!!!!!
I do have an engine crate but shipping would be on the buyer as I don't have a truck to get it to a terminal.
PM me
Jim
Pics added :
GM MLS head gaskets
Oil pump
Timing set
Oil pump pick up
Windage tray
Rear cover w/gasket
Cam position sensor
Oil pressure sensor
Fbod crank pulley
01 Fbod camshaft
LS1 water pump
Non-EGR LS1 intake
MAP sensor
Fuel rails
28.8lb injectors
TPS sensor
IAC sensor
PM me
Jim
Pics added :
