More LS1 stuff for sale...
Set of BMR Tubular LCA's with poly bushings. Black, non adjustible. Great condition. SOLD. I'll post pics of them tonight.
http://www.force-fed-fabrications.co...2/P1010119.JPG
http://www.force-fed-fabrications.co...2/P1010120.JPG
http://www.force-fed-fabrications.co...2/P1010121.JPG
Pair of stock TA 5 spoke wheels 16" with roadhuggers 245s. Wheels in good condition, tires have 60% life left. Asking $50.00. Pics:
http://www.force-fed-fabrications.co...e/DSC01261.JPG
http://www.force-fed-fabrications.co...e/DSC01262.JPG
http://www.force-fed-fabrications.co...e/DSC01263.JPG
http://www.force-fed-fabrications.co...e/DSC01264.JPG
http://www.force-fed-fabrications.co...e/DSC01265.JPG
http://www.force-fed-fabrications.co...e/DSC01266.JPG
http://www.force-fed-fabrications.co...e/DSC01267.JPG
LS1 block, with one cracked sleeve, otherwise ok. Have mains. I have two of these blocks with cracked sleeves, make a table or something. $75 each with mains, OBO. Pics:
http://www.force-fed-fabrications.co...2/P1010069.JPG
http://www.force-fed-fabrications.co...2/P1010072.JPG
http://www.force-fed-fabrications.co...2/P1010073.JPG
http://www.force-fed-fabrications.co...2/P1010074.JPG
http://www.force-fed-fabrications.co...2/P1010076.JPG
98+ center console for A4. Black. Decent condition. everythign works, no broken hinges, even the cupholder still works good. $75.00.
http://www.force-fed-fabrications.co...2/P1010077.JPG
http://www.force-fed-fabrications.co...2/P1010078.JPG
http://www.force-fed-fabrications.co...2/P1010079.JPG
Unknown fbody muffler, $10 Pics:
http://www.force-fed-fabrications.co...2/P1010080.JPG
Thunder Racing TR224 cam, 224/224/114 LSA 0.567"/0.567" lift. Less then 500 miles on it. Perfect. AskingSOLD!. Pics:
http://www.force-fed-fabrications.co...2/P1010084.JPG
http://www.force-fed-fabrications.co...2/P1010086.JPG
Stock 99 LS1 Cam. 50k miles. $25.00.
http://www.force-fed-fabrications.co...2/P1010087.JPG
Comp Cams stock length pushrods, less then 500 miles of use. $75.00.
http://www.force-fed-fabrications.co...2/P1010088.JPG
http://www.force-fed-fabrications.co...2/P1010089.JPG
ARP 12pt head studs for up to 03 LSX motors $175.00. Pics:
http://www.force-fed-fabrications.co...2/P1010101.JPG
ARP 12pt main studs for LSX motors. SOLD . Pics:
http://www.force-fed-fabrications.co...2/P1010102.JPG
LS6 oil pump. ported by thunderracing. SOLD . Less then 500 miles of use.
http://www.force-fed-fabrications.co...2/P1010103.JPG
http://www.force-fed-fabrications.co...2/P1010104.JPG
AFR 225 Heads. 72CC chambers. Stainless valves, just been replaced 14 out of 16 valves, I just got the heads back from AFR for warranty work. Upgraded valve springs, titanium retainers and locks. Under 500 miles of use. $2200.00 No waiting. Pics:
http://www.force-fed-fabrications.co...2/P1010091.JPG
http://www.force-fed-fabrications.co...2/P1010093.JPG
http://www.force-fed-fabrications.co...2/P1010094.JPG
http://www.force-fed-fabrications.co...2/P1010095.JPG
http://www.force-fed-fabrications.co...2/P1010096.JPG
http://www.force-fed-fabrications.co...2/P1010097.JPG
http://www.force-fed-fabrications.co...2/P1010098.JPG
http://www.force-fed-fabrications.co...2/P1010099.JPG
http://www.force-fed-fabrications.co...2/P1010100.JPG
Forged 346 rotating assembly. Stock crank, Eagle forged H beam rods and Diamond -8.6 forged pistons. This assembly has been machined and balanced to work together so I rather sell together. I made 950 rwhp on this assembly and everything is in great shape. Nice find for someone to build a cheap forged short/long block
Just put new bearings and rings on it and hone your block to the 3.905" bore pistons and it will be good for the same power again. Saves you money on machining shop costs. SOLD!.
http://www.force-fed-fabrications.co...2/P1010105.JPG
http://www.force-fed-fabrications.co...2/P1010106.JPG
http://www.force-fed-fabrications.co...2/P1010107.JPG
http://www.force-fed-fabrications.co...2/P1010108.JPG
http://www.force-fed-fabrications.co...2/P1010109.JPG
http://www.force-fed-fabrications.co...2/P1010110.JPG
http://www.force-fed-fabrications.co...2/P1010111.JPG
http://www.force-fed-fabrications.co...2/P1010112.JPG
http://www.force-fed-fabrications.co...2/P1010113.JPG
http://www.force-fed-fabrications.co...2/P1010114.JPG
http://www.force-fed-fabrications.co...2/P1010115.JPG
http://www.force-fed-fabrications.co...2/P1010116.JPG
http://www.force-fed-fabrications.co...2/P1010117.JPG
http://www.force-fed-fabrications.co...2/P1010118.JPG
Rather try to sell this stuff local since shiping SUCKS for most of it.
Just put new bearings and rings on it and hone your block to the 3.905" bore pistons and it will be good for the same power again. Saves you money on machining shop costs. SOLD!. http://www.force-fed-fabrications.co...2/P1010105.JPG
LCA's sold.
Head studs back on the market. I have 4 of the small studs stuck on the block so Im ordering replacements from ARP. Still $175.00.
Other prices lowered, need to get this stuff out of my garage.
I sent you PM.
