Parting out race car. lots of parts!
Old May 22, 2007 | 08:08 PM
Dustin@PremierAutosports's Avatar
Arrow Parting out race car. lots of parts!
everything here has under 500miles on it unless other wise stated.
AFR 224/228 581/588 cam $300
AFR 225 65cc small bore heads SOLD!!!
Nitro Daves stand alone fuel system (the one that replaces the battery) SOLD!!!
QTP stainless longtubes $500
MEZIERE electric race water pump SOLD!!!
spohn "drag race" alternator mount kit SOLD!!!
th400 reverse man valvebody trans brake (rated at 1400hp) $1100
yank SS3600 converter $650
denny's nitro driveshaft (fits th400) $300
moser 12bolt 3:73, spool, 35 spline axles, TA cover $2000
BMR tubular K member $400
Shohn weld in sfc's (brand new) SOLD!!!
Spohn adjustable torque arm with driveshaft loop SOLD!!!
Spohn adjustable panhard bar with rod ends $125
Spohn LCA's with poly ends SOLD!!!
QA1 rear coilovers single adjustable $475
BMR drag bar $350
weld prostars 15x10's and 15x3.5's
mickey thompson 325/50/15 drag radials(only 4 passes on them)
165/15 fronts SOLD!!
Old May 22, 2007 | 08:47 PM
Fast 90mm intake SOLD!!!
Nick Williams 90mm TB SOLD!!!
Fast fuel rails SOLD!!!
Old May 22, 2007 | 08:55 PM
otherwhitemeat's Avatar
if the welds fit a stock width rear end and are 7.5 in back spacing, i'll take the set, you would be shipping to mn 55123....let me know if that works
Old May 22, 2007 | 08:59 PM
they are 7.5" bs.
i would guess shipping on the rears would be like 50ea and prolly 25 ea on the fronts. that sound fair?
Old May 22, 2007 | 09:01 PM
stangeater01's Avatar
chat is the ds made of? i am interested
Old May 22, 2007 | 09:04 PM
also the alt mount what is this for do you have a link to the part
Old May 22, 2007 | 09:09 PM
CBRAKLR85's Avatar
what color is the BMR k-member? how old how many miles? stock rack?
Old May 22, 2007 | 09:12 PM
Originally Posted by Dustin601
they are 7.5" bs.
i don't think it will be that much...their is a way to check on line...but i'm not sure how.....either way if you can sell them shipped to me for under a grand then i'll take them and we can work out the details
Old May 22, 2007 | 09:16 PM
i believe the driveshaft is steel.
here is a link to the alt mount.
http://www.bmrfabrication.com/misc.HTM
the k-member is red, made for stock rack, and has mounts. under 500 miles.
Old May 22, 2007 | 09:17 PM
sounds good!
Old May 22, 2007 | 09:19 PM
mddndps's Avatar
Default Alt mount
Hi can you send pics of the alternator mount ,very insterested.Thanks Mark Mddevo@aol.com
Old May 22, 2007 | 09:58 PM
wheels and tires are sold.
alt mount pending.
Old May 22, 2007 | 10:19 PM
Ego Killer's Avatar
could you send me a pic of the pump?
crader_2000@charter.net
Old May 22, 2007 | 10:22 PM
Domstic1's Avatar
PM Sent.
Old May 22, 2007 | 10:32 PM
URLOSN's Avatar
who built the tranny, and how much usage has it had,
Old May 22, 2007 | 10:47 PM
it came from Transmission Specialties. it was in another car before this one. it prolly has a total of 1500 miles on it.
Old May 22, 2007 | 11:03 PM
dnkynrbk's Avatar
pm sent on the stand alone fuel tank.
Old May 22, 2007 | 11:11 PM
TimTaylor75's Avatar
PM sent.
Old May 22, 2007 | 11:30 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
pm sent.
Old May 22, 2007 | 11:46 PM
02TransAm/Batmobile's Avatar
are the spohn LCA's adjustable?
