DTC's FROM HELL!!!
So i have an ABS INOP and BRAKE light that came on out of no where a few months ago, well today i finally decided to hook up a tech 1 and scan it and the car threw ETC 16 and DTC 21, 22, 38, 41, 42, 55, 57, 62, 65, and 86.
I don't even know where to start! Im thinkin its time to do an ABS delete
Yeah
DTC 16 - ABS enable relay coil circuit open
DTC 21 - Left front wheel speed sensor = 0
DTC 22 - Right fron wheel speed sensor = 0
DTC 38 - Left front ESB wil not hold motor
DTC 41 - Right front ESB will not hold motor (DTC 86 is always thrown)
DTC 42 - Rear ESB will not hold motor (DTC 86 is always thrown)
DTC 55 - EBCM Malfunction
DTC 57 - Left front ABS motor circuit shorted to ground
DTC 62 - Right front ABS motor circuit shorted to ground
DTC 65 - Rear ABS motor circuit shorted to ground
DTC 86 - EBCM turned "ON" the red "BRAKE'' warning lamp
The relay is brand new and all the grounds and connections are fine. Im beggining to think the EBCM has gone haywire. I will try switching the relays just for fun but if i cant figure it out i guess its time for a delete kit with line lock...
