ARP bolts, TA mats, pistons, rings, motor mounts, slp fan switch
***All new unless I write otherwise.***
SOLD - new ARP harmonic balancer bolt for the crank - $20 shipped
SOLD - new ARP flywheel bolts - $20 shipped
SOLD - new ARP cam and cam retainer bolts - $10 shipped
SOLD - ARP hex studs for the heads that were only used to bore the engine - $160 shipped.
SOLD - ARP main stud bolts, installed to align hone a block - $100 shipped
SOLD - new GM pilot bearing, LS1 Exhaust Manifold Gaskets, FAST 90 mm TB seal. All $20 you pay shipping.
SOLD - Polyurethane motor mounts, new in the box, Poly Motor Mount Kit 1998-2002 LS1(both sides included) - $40 shipped.
SOLD - SLP Fan switch new - $30 shipped.
SOLD- Cometic MLS Cylinder Head Gasket, LS1 Engine, .045 thickness, 3.910 bore - $110 shipped
SOLD - Morel new solid lifters - $300 shipped
Sale Pending - MBA Pontiac rear fascia letter electropolished - $30 shipped
Sale Pending - new SLP Smooth High Flow Bellows - $20 you pay shipping. Expect it to be about $9 - $12.
Sale Pending - EFILive - FlashScan Commerical Scan&Tune, new in the box. Never got around to flashing my PCM with this version. Used LS1Edit before this. This has a 6 VIN license. That alone is $600. The version is 1.2. Selling for new price of $450 shipped.
Stainless steel studs for the oil pan, new in the package - $20 shipped.
Diamond pistons, rings, and black TA embroided mats on ebay.
MBA billet door sills satin 93-02 F-Body - $100 shipped
MBA Trans AM door emblems 93-02 f-body Electropolished - $80 shipped
2000-2005 MITSUBISHI ECLIPSE ALLOY FUEL DOOR GAS JDM - $60 shipped
USED LS1 harmonic balanced I think it was an early ASP pulley - plan was to reuse it - $50 shipped.
LS1 shaft Comp cams rockers. Stock ratio. Bought used. Told only used on dyno. Appear perfect. $300 shipped. Beautiful rockers. If you can't tell from everything I have been selling I was only going to put the best stuff in this car (IMHO). On ebay.
Ford racing #30 injectors, new $300 shipped
Aluminum steering pulley - need to see in pics - $50 shipped
CCW 19" wheels, new in the box. Retails $3300. $2000 plus shipping
new in the box Racetronix Fuel System w/ 255 LPH High-Pressure Fuel Pump and Series II Plug-&-Play Wiring Harness (includes chassis ground & booster pump plug-&-play option), 1999-2002 LS1 F-body w/ plastic fuel module (bucket) & Plastic gas tank $180 plus shipping.
Will entertain all offers.
I have pics of all.
I have pics of all.
if the SLP fan switch is new and hasnt been installed and is the same one from SLP that manually controls the fans I will take it PM me or email me at tiresmoke76@aol.com thanx
