June Nitrous Specials!!!!!!!
Old May 30, 2007 | 02:59 PM
Nitro Dave's Nitrous Outlet's Avatar
Default June Nitrous Specials!!!!!!!
Ok, Guys it is summer time and June is here. Only a month or tow before it starts getting really hot out. Now is the time to get the car going and at the track before the summer heat sets in.
To help you get your builds going we have put together a few specials for the month of june.. Here they are..
Group 1
Nitrous Outlet LS1/LS2 plate system with 10lb bottle.Your choice of 78mm or 90mm.
Automatic bottle heater
Nitrous pressure guage
Fuel pressure safety switch
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
Digital dual window switch; wide-open-throttle detection, multi-gear lock-out setting, built in TPS, supports low voltage tach signals, works w/ irregular tach signals, push-button programming with integrated LED digital display, Compact rugged, waterproof design.
Also includes (8) NGK TR6 spark plugs.
COST- 1,115.00
Group 2.
Nitrous Outlet 58mm LT1 plate system with 10lb bottle.
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
Image comming soon...
COST-1,115.00
Group 3
(For you Corvette guys)
Dual nozzle dry system.
Nitrous pressure gauge
NHRA fitting
Blow down tube
Automatic Bottle heater
Nitrous Outlet purge kit
Nitrous Filter
Digital dual window switch;wide-open-throttle detection, multi-gear lock-out setting, built in TPS, supports low voltage tach signals, works w/ irregular tach signals, push-button programming with integrated LED digital display, Compact rugged, waterproof design.
NGK TR6 Spark Plugs
Image Comming soon
Cost 820.00
Group 4
(For you GTO Guys)
GTO Halo system
NHRA filtting
Blow down tube
Automatic Bottle Heater
Nitrous Filter
NGK TR6 Spark Plugs
COST- 845.00
Group 5
(For you 98-02 F-body guys)
F-Body Halo system
NHRA filtting
Blow down tube
Nitrous Filter
NGK TR6 Spark Plugs
COST- 845.00
Group 6
(For the Guys running a cone style filter), (GTO & GM TRUCK)
Conical style filter system
NHRA filtting
Blow down tube
Nitrous Filter
NGK TR6 Spark Plugs
Image Comming soon
COST- 845.00
Discounted Items of the month..
Selection 1.
THE BIG SHOW purge system.
If you are looking to make an impression at the start line this is the purge kit for you. Its called THE BIG SHOW FOR A REASON.....
This purge system comes with a large 500hp solenoid, 3 ft of 1/4inch alluminum tubing, purge button and all fittings needed.
With this special we are throwing in a free relay and harness incase you do not already have one.
COST- 95.00
Selection 2
Nitrous Express 10lb bottle
COST=180.00
Selection 3
Zex Bottle Pressure gauge & Manafold
COST-37.00
Selection 4
Nitrous Express Power Booster.
COST-10.00
These specials are good until the end of June.
You can call in your order toll free at 1-866-648-7637
Thank You for your support
Dave
Old May 30, 2007 | 06:30 PM
Selki's Avatar
PM sent
Old May 30, 2007 | 08:45 PM
Boostaholic's Avatar
No discount on standalone fuel system combos?
Old May 30, 2007 | 09:51 PM
MetallicaMatt's Avatar
Dave-
do you have anything that I can connect a SS braided line to my NOS bottle (hi-flow valve) to use for my blow down tube? I don't like the tacky aluminum one, plus I need more length.
Old May 30, 2007 | 10:47 PM
Sabre002's Avatar
do you have any deal on the base LS1 plate kit? Stock TB size.
Even thought I really would like to have that 1st setup man I might just have to save for it.
Old May 30, 2007 | 11:41 PM
mellowyellow's Avatar
Yea Dave what about a special on Stand alones....Cash in hand...Errr On card that is...LOL...
Old May 30, 2007 | 11:49 PM
indeed, i was thinking something like a addition to the ls1 plate kit thats up there now, buy that kit and get a discount on the fuel system? even though all that together is a pretty heafty chunk of change, maybe i should be lurking in the suspension forum
Old May 31, 2007 | 12:42 AM
caliswangin916's Avatar
we the people want a 10% discount for any orders over $50............................................... .................................................. ....................................... and free shipping?????
Old May 31, 2007 | 02:02 AM
4yall2nv's Avatar
thinking of a stand alone sytem also, any group purchases or discounts?
Old May 31, 2007 | 04:14 AM
dannyz's Avatar
not bad.
Old May 31, 2007 | 09:06 AM
talk about give them an inch and they want a foot!
Old May 31, 2007 | 09:13 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by ron williams
dave do you sell standard nitrous kits? i mean the type wet or dry for carb type cars,with the under carb plate like for holley 4150? i'm looking at a 100 shot, NOS, NX, EDELBROCK..ETC. single stage on a button . built race motor chevy small block...............thanks RON
yes we carry the complete line of carb kits...from NX, NOS, and ZEX
http://www.nitrousoutlet.com/catalog...del=44&dept=11
Old May 31, 2007 | 09:14 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by MetallicaMatt
Dave-
we offer a universal blow down using braided hose and Earls fittings.
http://www.nitrousoutlet.com/catalog...roduct_id=1116
Old May 31, 2007 | 06:21 PM
how long is the hose on that kit?
Old May 31, 2007 | 06:38 PM
00silver6's Avatar
is there any deal on dave's plate?? just the plate i need a badass conversion!!
Old May 31, 2007 | 08:49 PM
defenestrate's Avatar
Default This Sucks
woooow what timing i had just made an order on 5/14/2007, and here it is
automatic heated bottle bracket 216.5
window switch 129.
tr6 plugs 15.92
T SHIRT 14
dual vent purge 34.99
big show purge 119.
halo system 499.99
for a total of 1,029.40
i know i ordered the big show purge instead of the regular (do i need a harness?), and the bracket heater, but is there anyway i can get refunded for some kind of a discount? i just threw down a lot of cash and i sure could use and would appreciate some kind of refund... show me that top of the line customer service!!
Old Jun 1, 2007 | 12:06 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
standard is 3'...we can add more if you need it
Old Jun 1, 2007 | 01:13 AM
94'BLKBRD's Avatar
do you guys have a plate for a stock size lt1 throttle body??
Old Jun 1, 2007 | 01:19 AM
jetlag's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
Group 1
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
COST- 1,115.00
Will this kit be everything I need to safely and correctly install nitrous onto my car? I don't want to have to be trying to scavenge around for extra brackets or pieces...for my 05 GTO...
How much is shipping to 38654?
Old Jun 1, 2007 | 01:21 AM
911ss's Avatar
that everything and a lil extra matt....
