10 lbs of LS2 in a 5 lb BMW - 56k forget it
Old 06-02-2007, 05:16 PM
rao
rao's Avatar
Default 10 lbs of LS2 in a 5 lb BMW - 56k forget it
More pics than you really want.
I don't post much here, but I know some people are interested in this swap.
Actually it fits with room to spare
Went in without a hitch, although I broke the oil pressure sender, which I have done very time I have ever put a Chevy motor into anything - if I was smart I would install that after the motor is in
Unfortunately the motor will have to come out to install the exhaust manifolds but this way the wiring and other plumbing will be easier to do and it is a good place to store the motor and transmission.
Open wide
Fits
Driver's side clearance
Passenger's side clearance
Back to normal ride height
Hood closes
Throw out bearing
LS2 Flywheel (yes I removed the inspection sticker)
LS7 Clutch disk and Pressure Plate
M Coupe Radiator and Ford Taurus 3.8 Fan - the look like they were made to go together
I think I could fit 2 radiators in there
Lots of space
Old 06-02-2007, 05:22 PM
RacnJsn95's Avatar
Wow! That's awesome!
Old 06-02-2007, 05:41 PM
Sled's Avatar
Looks like it will be sweet, keep us up to date.
Old 06-02-2007, 09:46 PM
PRAY HRD's Avatar
really nice project you got there!
Old 06-02-2007, 10:17 PM
Sabre002's Avatar
Nice anymore details about the mounting? You make it or get it from a shop? Also will the car have AC and PS? After I'm done with the RX7 I'm looking to make something a little tame I was thinking about a BMW swap or I would like a Typhoon haha but dont we all.
Old 06-03-2007, 07:26 AM
Rob
Rob's Avatar
Looks great! But it also looks like an LS1 from the TB and timing chain cover.
Old 06-03-2007, 07:45 AM
rao
rao's Avatar
402 forged LS2 block, LS1 electronics. I got the mounts from www.nash8503.com
AC and power steering (the PS is a must since I am using a hydro boost brake booster)
This car will be have a lot more power than either of my RX-7 swaps, plus it is roomier and much nicer
Old 06-03-2007, 11:12 AM
Sabre002's Avatar
wow that price is crazy for the conversion parts.
Old 06-03-2007, 06:10 PM
rao
rao's Avatar
I know - everyone and their brother could start with a block of iron ore and build an entire car in about a day in their back yard for $5 Where is ChrisV when you need him?
That price is for every nut, bolt, wire, relay, tie wrap and everything else needed for the swap, including custom made stainless headers. I am using a lot of his parts, but not everything.
Old 06-04-2007, 08:10 AM
rao
rao's Avatar
More pics, bumper off and alternator and power steering pump installed:
Old 06-04-2007, 10:51 AM
Blackboosted2's Avatar
Looks nice! Once I finish getting the Vette nice and modded, I am going to look for an M3 to tear apart.
Old 06-04-2007, 02:13 PM
Geezer's Garage's Avatar
Nice progress. Have you hit any unusual roadblocks?
Old 06-04-2007, 02:37 PM
Gen3Benz's Avatar
Sweet!
What headers/manifolds will fit?
Old 06-04-2007, 02:44 PM
Gen3Benz's Avatar
Sweet!
What manifolds are you using?
Old 06-04-2007, 02:58 PM
Tootall's Avatar
that's different
Old 06-04-2007, 03:46 PM
rao
rao's Avatar
The only road block so far was my decision to rebuild the entire suspension front to back.
The headers are custom made. They should be here later this week.
Old 06-05-2007, 01:37 PM
freezingtexan's Avatar
Out of curiosity, why did you mount the engine so far above the crossmember and at an angle? On my LS1 E36 swap I have the oil pan practically sitting on the crossmember.. I ground down some of the rack support brackets to get the engine even lower.
Car looks nice!! You're gonna have a blast.. I've just got a stock LS1 in mine and it flies!!
Old 06-05-2007, 01:40 PM
95GreenZ28's Avatar
Nice swap!!
Old 06-05-2007, 04:05 PM
rao
rao's Avatar
Because I like it that way Actually it is about 1/8" off of the steering rack braces and I would not feel comfortable griding those down. The trade-off to get another 1/4" - 3/8" inch lower is not worth it to me.
Old 06-26-2007, 05:08 PM
rao
rao's Avatar
Headers:
Quick Reply: 10 lbs of LS2 in a 5 lb BMW - 56k forget it
