LS1 swapped into an EVO!
I searched first so I hope this isn't a repost, but this just looks odd. Something just doesn't look right, but they say the car runs and drives!
Motor is sitting at a hellacious angle, that drive shaft has to be hurting. Blower isnt hooked up yet, probably because he still needs to make piping. Notice the air filter.
will jents
i have seen this car last night it was running ideld prety damn good , ans yes the blower is still no hooked up due to rush to get it on the road for these fotos
i can tell you one thing you should have seen the look on the evo owners face that were there
it was worth 1000000000000000000$
guess i should post up the writeup:
Started with a regular run of the mill evo 7 , decided to make it a “real” car by putting a real engine in it.
First the stock evo engine and transaxle were removed from the engine compartment for the mock up process. After placing the mockup ls1 in the engine compartment ( with the proper north-south orientation) it came apparent that the stock evo cross member had to be modified to fit. The [problem was interference with the oil pan and the placement of the steering rack. To address this issue it was decided to relocate the mustang steering rack from the rear to the front of the cross member (converting it from “rear steer” to “ front steer”) , to make this swap possible a whole new cross member was fabricated . The stock front lower control arms attachment points were left in place and the rest was chopped off and replaced with the custom made unit that attaches to those points and frame. To make the relocated steering rack work the left and right steering knuckles were swapped around so the tie rod attachment points were in front of the front axle centerline. Furthermore, the steering shaft had to be modified; it was lengthened because the rack was moved forward and had to be moved outward due to interference with the engine block. The nice thing of the cross member is that it provided ample room for headers to pass through.
The cross member utilized stock Lumina motor mounts and stands to locate the engine, which was placed as far back as possible. The plan was to run a t-56 six speed but it was decided to simplify the process by installing a th-400 first and getting the car running, and then convert it to a six speed. Due to the placement of the engine, the firewall had to be cut and the transmission tunnel “formed” to clear the bell housing. The tranny was mounted using a custom cross member ( read : a welded bar with a hole in the middle ) the cool thing is that the hurst auto shifter pokes up at the same location as the original.
Stock evo radiator handles the cooling, but the fan was swapped to one that cleared the water pump and pulleys. A custom drive shaft connects the tranny to the stock rear diff. Fuel system consists of a Toyota Echo tank placed in the trunk, with dual bosch 420 lph pumps that feed an Aeromotive regulator in the trunk and feeds the engine through –8 braided line. The interior is as stock as an evo can be , except for the hurst shifter that will be shortened to make it look like a stocker and the addition of an 8 pt. Roll cage, the rear seat bottom has been temporarily removed, and incase you are wondering , yes it has a fully functional AC.
The engine is an iron blocked LS1 6.0 with forged diamond pistons and forged rods and crank. Ported heads and victor jr. intake manifold with a 100 mm throttle body. Compression is at 8.5 :1 with a big cam to help with the D1-SC procharger . The intercooler is a custom front mount air-to-air cooler. The only drawback to this setup is that the hood had to be cut a bit to clear the throttle body. The headers were custom made in alotaibi exhaust shop and are full-length headers with one bullet muffler on each side (no H or x pipe yet). Incase you were wondering why the gas tank was relocated to the trunk its because the stock tanks were removed to make room for real mufflers in the near future.
as for the blower piping , its all there , including the intercooler. its just off cause the drive pully was damaged.
the engine angle is just fine, its the slope of the hood that is big.
as for the oil pickup , its just a camaro pick up and pan.
and incase you are wondering, it didn't cost an arm and a leg. most of the done was done in his garage. a major part of the funding for the project came from selling the old evo engine,tranny and xfer case ( i even think he still some left ) . the blower came off his gto. and he assembeled the engine with forged pistons and rods.
as for the AWD system , it will come eventually. planning to use the tranny, transfercase, front diff and oilpan from an envoy to make it work.
currently the car is lighter than original. the front coilovers are lowered all the way and the tire/fender gap is bigger than stock!
Originally Posted by sultan(ZR-1)KSA
will jents
the pic is missleading. the car was parked on a ramp and the fenders on the evos have a strong rake to them.
i might snap a pic with a level on the fule rails to show you how regular the angle is.
as for cranking the boost, well lets put it this way : this is easier and more dependable.
we have a couple of "highly modified" evos here which make 540 crank hp on C16 and if you see the amount of money and work that had to be done to make them reach that level you would just think "why?? " you end up spending two times more than the price of the car to make that level of power.
in this case, the car can make 600 rwhp very dependably and still be a great daily driver all on pump gas ( the thing still has AC) all while costing less than the price of his old engine and transaxle.
Hmmm...Ok. Now that its becoming more apparent that this is for real...Im starting to become more interested. I see the question "why" popping up. And my question is "why not?". People are putting LS1's into everything now. Domestics, imports, classics, boats, hell even planes... I dont think it LOOKS really good. Mostly because of the weird angles. But hey, if its not a show car who cars right? I bet once its totally finished up its going to be a hell of a ride.
The other EVOs and STIs wont know what hit them....or what blew by them. I say good show...good work...and good god get us more pics and some video of the thing running!!!
Justin
Justin
guys trust me the angles are ok , its just that the car was parked on a ramp.
i'll get pics with a level on the fule rail to show you .
(note: i drove the thing and its a blast! can you say instant drift!)
ok guys I am the owner
thanks sam for the write up ,about engine angle it's almost like transam engine angle
here is the pix
#1 is a level on TM fuel rail
#2 is a level on evo rail
here is the pix
#38
Originally Posted by kinimod
Bubble is way to the side
Hmm, I thought about doing this to my 95 Eclipse
#39
1dirtyZ,
Why the victor jr. intake? Seems as though cutting the hood could have been avoided by using a Weiand intake w/ possibly only a slight difference in volumetric efficiency due to the flow differences.
