CPT Pro Race 4l65E w/ TCI 3500 TC $1100
CPT built 4L65e w/ 3500 TCI converter $1100. This tranny has every bell and whistle with a harden output shaft. It held low 11 second passes with no problems. It blew a rear seal and has since been repaired and checked out. I recently bought a 4L80E for my car and no longer needed it. The tranny is right now in Durham NC at CAM. This tranny has all the goodies and has less than a 1000 miles on it. I ve moved up to a 4L80E. So I no longer need it. It is built with all the premium parts and it should hold 700hp with no problem. It has a Custom shift kit, Fairbanks "Billet" 2 nd servo, Sonnax "Super Hold" 4th servo, .490" Sonnax pressure regulator boost valve, Alto "Wide" Red Lined 2-4 band, 7 Raybestos "Blue" 3-4 frictions, "Kolene" friction coated 3-4 steels OR Raybestos "Z-Pack", Sonnax "High RPM" pump slide spring, "The Beast" H/D sun shell, New Borg-Warner 29 element input sprag, 4L65E front support, 4L65E hardened output shaft, and updated steel piston set for the input drum. A TCI 3500 TC comes with it. Here is the builders website. http://www.cahallperformancetransmissions.com/
and a vid of the tranny at the track. You can not feel this tranny shift at WOT
Vid of tranny running
My number is 757-508-0684 Ask for Chris. The tranny is at Carolina Auto Masters in Durham, NC. Will Ship at your expense guys. I also have a Alum lingenfelter driveshaft for this that I will throw in cheap for like a $100 extra. Please call if interested.
